4 members (KEVINSKI, FishinToms53, Gdads51, Peggy M), 114 guests, and 0 robots.
Topics128,052
Posts1,055,740
Page 3 of 3 1 2 3
Thanks for the work Paul.
Red dot, center of chest ...
Gdads, not from the same server. From the same network. I have no problem blocking entire networks in China. They are more likely to be nefarious than not. Blocking entire networks in Europe is a lot more problematic. The problem is, when you block single IPs, the bad guys can just move to a different IP. So then you're playing whack-a-mole.
When you list 217.113.194.XX, you're describing a class C network. I have no problem blocking them. If this continues, let me know, and I will block it.
I've also decided to keep a much closer eye on awstats, because that can show us the bad actors very quickly.
https://www.stovebolt.com/awstats/awstats.pl?config=stovebolt.com
If you click on Hosts/Full List, you will see the two Chinese IPs stand out.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Paul, Thanks for the explanation as always. My limited knowledge in this continues to grow with your feedback and explanations. Those particular "Guests" were not showing up in WOL this morning. I will report further if they or something similar is discovered. Thanks you again!
~ Dan
1951 Chevy 3 window 3100
Page 3 of 3 1 2 3
Moderated by  baldeagle, Gord&Fran
