4 members (RoadsScholar, Mike Roache, moparguy, 51sub), 108 guests, and 3 robots.
Topics128,070
Posts1,055,892
Members48,428
#155980 09/02/2003 9:51 PM
Anonymous
Unregistered
Anonymous
Unregistered
#155981 09/02/2003 10:15 PM
Yeow!!! Makes one tear up just thinking about it.....
#155982 09/03/2003 3:31 PM
And I thought running my finger through the table saw was bad. Safety glasses didn't help that, either.
OUCH eek
Fred
52 3600
69 C-10
#155983 09/03/2003 4:46 PM
Ripleys believe it or not! Very lucky to only have lost the eye and nothing else!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#155984 09/06/2003 1:22 PM
Eeeeeeewwwww.
#155985 09/07/2003 3:42 PM
Caution, operating this tool too close to the eye socket may cause serious injury or death.
54 3100 with 235
62 flatbed dump C60 with 261
#155986 09/18/2003 1:15 PM
JEEEEEZZZZ...I need a shot of morphine just readin' it.
#155987 09/18/2003 4:27 PM
I was doing OK until I saw the X-Ray! Ohhhh Maaan!
Now I can refer folks to an image to describe the way i feel the morning after drinkin' too much! eek
#155988 09/18/2003 4:39 PM
I suffer vascular headaches (sort of like migraines), the X-ray is what I feel like during an attack.
54 3100 with 235
#155989 09/19/2003 7:35 PM
I knew a guy named Rob, he owned a bodyshop, Celtic Coachworks, oncehe had an accident with a cutoff wheel, the small 3 inch cutting disk exploded, the shatters went thru the full face lexan shield and he lost an eye. It was pretty tragic, because we all can understand that using a face shield or gogles can make us safe.The lesson was that although losing an eye he was still better alive because if it were not for the shiled, the doctors told him that the shapnel would have reached his brain. After that, I retired my cut off wheel, having it as an unsafe tool, even with the adequated protective equipment.
Alexandre Garcia
#155990 09/20/2003 4:57 AM
Anonymous
Unregistered
Anonymous
Unregistered
Alexandre,
My brother was running a large chop saw used to cut structural steel tubing and bar stock. It had a 20 inch abrasive blade and a long handle so you would stand about 4 feet from the blade when it was cutting. Even though it was water cooled it still sent a huge shower of sparks everywhere.
One day the blade shattered and a piece caught him inside the thigh right below the groin. His blood was pumping out of him like a water spigot. Good thing the Seattle Fire Dept was right next door and the hospital only a few minutes away. From that point forward, air cylinders were used for all material clamping and the chop saw was raised and lowered with air cylinders as well. No one can stand in the path of the blade.
Moderated by  MNSmith
