1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Can I get some confirmation or did someone do some reaming.
Cleaning up a 3600 project tie rod ends, rod and arms.
Current ball ends have castle nut style on both the 3600 3/4 ton. But when I went to put the newer 55-59 replacement ends on the tie rod and on the steering arm the new ones don't fit the 3600 steering arms. Looks like they are 5/8 tapered and 3100/3200 are 1/2.
The ends came from a classic parts vendor full kit rod and tie rod ends supposedly for all 55-59 trucks which i now assume meaning all 3100/3200 1/2 tons.
The rod ends that came off were definitely old style originals.
Thoughts? and/or reality | | | | | Joined: Sep 2009 Posts: 6,035 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,035 | hcb, your topic will probably get better answers in the Driveline forum, do it’s been moved there for further conversation and help. Someone should be along soon to hopefully help out.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | After some heavy research. It is confirmed that the 3/4 ton trucks have a different taper size on the ball stud for tie rod to steering arm. There are new replacement studs available on several of our normal parts sites for old trucks . For those of you using stock/original tie rod ends this is not an issue as they fit both 3100/3200/3600 trucks and some larger.
For those of you "upgrading" to new style tie rod ends with a sealed ball joint. the 3/4 ton version with large shaft taper are NOT readily available. There are plenty for the 1/2 ton 3100/3200. For the 3/4 ton I found one site that had the newer tie rod end and they wanted hundreds for it. I think they make them custom.
I had 3600 ball studs and stock tie rod ends so I just used those on the new larger tie rod. | | |
