4 members (wilbur53, 2-Ton, 2 invisible),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | My meter shows a drain on the battery while parked. That normal? No accessories on line.
1942 Chevy 1/2 ton 2014 RAM Truck
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | If on the 1942, no, that's not normal. If you're looking at the stock ammeter, possibly the needle has been tweaked toward the discharge side. Have you connected a real ammeter (like a Fluke Multimeter) inline at the battery to see what it shows?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Not normal. Nothing on a 1942 truck uses power when the truck is turned off.
Keep your meter connected and then go around the truck from one circuit to the next disconnecting items one at a time until you see the drain stop. Then you'll know what circuit to start checking for frayed wires or bad connections or whatever.
I'd start with the ignition switch / circuit. Disconnect the hot wire to the coil. Maybe it's staying on when the key is off and sending power to the points. Check them to make sure they aren't burned. Check the coil to make sure it isn't getting hot.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | A disconnect switch would just mask the problem. You don't want a faulty circuit to start a fire. I suffered a total loss electrical fire 4 years ago while driving. Not something you want to have happen with your truck
| | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | My Fluke 77 reads 99.7 ma on my 42. I Will check ignition next. Nothing else is wired in except a new regulator/generator which is charging normal.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | That is a *lot* of current for an off state.
As a point of reference, my 2004 Denali with all the permanately powered computers and memory and stuff draws less than 1mA with the ignition off.
You have something fairly significant drawing current. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I agree with Jason. The spec for my F250 7.3L is 50 mA or less when everything is asleep.
When you say new regulator/generator, if it's actually an alternator, it's very likely that a diode has shorted and the battery is trying to power the alternator as a motor. That'll drain the battery in short order. It may still charge the battery normally. Easy to check. Pull the power wire off the generator and see if the draw goes away.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | I stayed with the original generator.
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Possibly a sticking relay in the voltage regulator. There's one that's supposed to cut off the wiring to the generator with the ignition off.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | A sticky cutout relay will discharge the battery in a matter of minutes, and probably smoke a lot of wiring in the process. Does the ammeter center itself when a battery cable is disconnected? Jerry
| | | | | Joined: Jan 2022 Posts: 2,448 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,448 | Does the ammeter center itself when a battery cable is disconnected? Jerry I'd be real surprised if the ammeter would show the difference between zero amps and the reported 0.0997 amps.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | But on a side note unrelated to your issue, my '37 has a battery cutoff switch, I use it for anti-theft and battery saver. I have purchased two batteries for the truck since 1999 and one was a Walmart. I shut it off every time I get out no matter where I am or how long I will be staying. | | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | I found it !!! 6 volt + from the fuse panel was attached to the fuel gauge without a sending unit attached. I've got 0 Ma. drain on the batt. now. I'll need to get 6v B+ from ign. Switch if I use the fuel gauge.
| | | | | Joined: Aug 2021 Posts: 29 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 29 | Thanks for everyone's help. That miswire was my oops.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Good deal. Thanks for letting us know that you solved it. | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 |
