Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (GMCJammer51, Bill Hanlon, 3B), 58 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1558417 09/20/2024 7:56 PM
Maybe a dumb question. Are tachometers voltage specific. 6v vs. 12v? I want to add a tach to my 6v system.
Dave from Northern Kentucky
My 54 3100
dgrinnan #1558418 09/20/2024 8:00 PM
Most are not. In my limited experience.
Professional Novice
dgrinnan #1558423 09/20/2024 8:55 PM
It depends on the vintage. Most newer ones will be voltage dependant because they use the primary voltage to run the sensor and drive the needle.
A lot of older ones were not.
Do you have a specific tach you are looking at? We could potentially help you evaluate whether or not it will work.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
dgrinnan #1558433 09/20/2024 10:25 PM
B Online: Content
Here's a uneducated guess: If the tach doesn't have a separate 12v power wire it will work on 6 or 12 v.
