| | | Forums66 Topics128,117 Posts1,056,296 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Sometimes we don't have that "certain" tool in the box, so we need to become a "Mcgyver" and make a tool. One that I have used is for tube bending.
Creating nice, non-kinked bends in tubing is best accomplished with a tube bender. Unfortunately, benders only accept tubing of certain diameters and generally can only make one radius,(or you loned it out to a fellow Stovebolter-LOL). For alternatives, look no further than your engine to find a variety of potential tubing benders: the fan-belt pulleys. While it is nice to use some old pulleys in a vise, pulling the fan belt and working in the engine compartment can get the job done, too. All assuming the use of the V-belt- not serpentine belt- pulleys, of course. When ever I see different sizes of V-belt pulleys, I grab them quick.
Does anybody have more of these ideas?
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | OLY!!!!! are you that broke that you have to do tricks in the shop????
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have found that the Mechano toy wheels, the large ones are pretty handy for bending tubing. You can even straighten out the bend using one if you apply just right. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Don't know about Oly's wallet, but mine is a bit on the dusty side. whooosh - Blows off dust
One project I have considered getting around to is a Battery Charger.
12v DC Battery Pan Dual Pattern Battery Cables 120 Amp (rebuildable) Alternator w/V belt sheave Volt Gauge Ammeter 10g wire
Belt
120v AC AC 1/2-1 HP 1ph 60hz Motor - NEMA FRAME - 56 Light Switch Fabricated Base/Alt Mount Brckt 14g Grounded Cord
What am I forgetting? | | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Not forgetting anything Chief except that this could also be done on a "portable" basis. Years ago I used a Lawn mower Briggs and Stratton engine and generator and voltage regulator and mounted it all on a wooden platform. I didn't have AC electric so it worked great for me.
Another trick I learned, in my days of four-wheel drives, was how to keep the bolts from vibrating loose and loosing parts and pieces along the way. (Might come in handy for bouncy Old Stovebolts-LOL) Nylock-type nuts (the type with a built-in piece of plastic that serves as an anti-vibrate-loose device) are great, but who always has the right size on hand? I made my own, although certainly not the real thing, but close enough. A piece of fishing line or weed-whacker string jammed in the threads nevertheless can do an adequate job in most instances.
| | | | | Joined: Nov 2000 Posts: 119 Member | | Member Joined: Nov 2000 Posts: 119 | I have two sets of rollaway tool chests. I wanted to put a rubber pad between the upper and lower units, but Sears wanted something like $16 for theirs.
I went to Wally World and bought black rubber door mats for less than $3 each. Trimmed them with scissors and they worked great!
---> Bill | | |
