10 members (Bruce 1954-4100, frogfarmer, DennisM, Joe H, Joe Lowe III, Shade Baby, 3B, Oswald, Cosmo, 1 invisible), 73 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
I have a 49 3600
The generator pulley is rubbing the generator making a tinging noise.
it was doing it last year and I found the nut was loose tightened it and the noise went away.
The generator seized up last week I ordered a generator swapped the pulley and it is doing it again.
is there a spacer between the gen and the pulley ?
Thanks John
What part of the pulley is rubbing the generator? Can you post pictures? Is the pulley pushed too far onto the shaft?
1950 Chevrolet 3100 (Ol' Roy)
Riding in the Passing Lane
If it is just part of the pulley hitting it must be bent. Find the low place & bend it out with a large screw driver.
George
1972 Chevy c10 Cheyenne Super
Thanks guys
It only one side so I'll go from there
Just wanted to make sure I wasn't missing a spacer or something
A thin spacer between the front bearing and the fan can be fabricated from a flat washer if necessary- - - -use a "SAE" washer, which has a smaller outside diameter than the usual hardware store item- - - -plenty of them available on Ebay.
7
7 Offline
If the sheave was loose on the shaft, it is likely that the bore is now worn and may never fit snug enough to prevent it from a slight wobble, that will cause the nut to loosen again.
