2 members (Kilted54, UtahYork), 72 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
I had my truck idling to warm up and I could smell fuel. When I popped the hood, I could see that the fuel was leaking around the in-line fuel filter. The clamps on the rubber hose had loosened up somehow. That reminded me how dumb I am for not having an easy to access fire extinguisher inside the cab. What kind of fire extinguisher do you guys have and where do you have it mounted?
Mike Barnes
1950 GMC 1-ton pickup
Authorized Pest
Authorized Pest
THIS is a very good question.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
24601
24601
Excellent question!
The one in my '49 1-ton is an ABCD fire bottle (good for use on petroleum fires and electrical fires) and it's mounted where the fresh air heater would go if my truck had one. I just used the screw holes for baffle plate (that blanks out the opening for the fresh air heater) so I didn't have to drill any additional holes in my cab.
If you have a heater there then obviously you won't be able to put your fire bottle there.
smile
Fire bottle mounted where the fresh air heater would go.
It doesn't seem to be in the way
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Mike,
Glad you are thinking about this before it's too late. My Halon in a similar location as to John's.
Craig
Thanks for the replies and for running this wonderful site. That’s a good place for it, but I do have the fresh air heater. Horizontally mounted in the center of the seat apron would be convenient if it’s acceptable to have it mounted horizontal.
Mike Barnes
Hagarty had an article on a stick fire extinguisher, see elementfire.com.
Compelling device when u read up on it, I have one clipped in the center of the 46 seat riser
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Authorized Pest
Authorized Pest
Chuck, can you snap us a picture of the stick fire extinguisher and post it? Is THIS the Hagarty article you were referring to?
~ Peggy M
1949 Chevrolet 3804
I checked out that Fire stickfire stick and it sure does look like it would be perfect. It’s small enough to mount anywhere.
Mike Barnes
Authorized Pest
Authorized Pest
Taken from their website:
WORLD'S SMALLEST & LONGEST LASTING FIRE EXTINGUISHERS
The advanced science of Element only needs a small package that is 10.75" tall, 1.2" in diameter and weighs less than 0.5 lbs. You can store Element anywhere and it will provide 50 seconds of discharge that will extinguish all major classes of fire (ABCK) without leaving a mess or causing additional damage.
Incredible. Has anyone tried one of them? Just curious. headscratch
~ Peggy M
1949 Chevrolet 3804
Sounds like something I might look into, to replace the old Halon
Craig
I put mine on the front of the seat riser under the driver. I don't have room in the middle due to the T5 shifter. My feet are pretty much always stretched out toward the pedals, and the floor space on the passenger side is still open for stuff or people with stuff. Only thing is, I inadvertently mounted it so it's pinching the mat, so if I need to pull the mat up for some reason, I have to take the extinguisher out of the mount.
Speaking from experience, unless you have a BIG fire extinguisher, the kitchen sized units are useless in an actual emergency. They have about 10 seconds of spray and then they're done.
Keep one in your car by all means. I have one in every vehicle I own but a total loss fire 3 years ago in one of my vehicles showed me how pointless they really are.
You will be better served by carrying a FIRE BLANKET in every vehicles. If I had one of those instead of the fire extinguisher, I could have smothered the fire before the entire vehicle went up in flames.
The reason I started carrying extinguishers in the first place is because of a fire under the hood of my 68 Camaro in college. Luckily I was at home when I saw the smoke. I ran into the barn and grabbed a quilt that we used to lay on while changing oil or whatever.
I put out the fire immediately and only had to replace plug wires and other rubber stuff. The wiper motor had caught fire.
I found out many years later after the advent of the internet that Chevrolet wiper motors in 1968 had a known flaw and caught fire for no reason.
Anyway, fast forward to 2021 where I discovered that in a real emergency with an underhood electrical fire, the extinguisher ran out before the fire was out and the entire car went up in flames. A blanket would have smothered it in a few seconds when it was just getting started.
1950 Chevrolet 3100 (Ol' Roy)
Late getting back on this, here is the link to the Hagarty article on the fire stick with pix, the device puts out a 50 seconds continuous stream of fire stop with little or no residue.
https://www.hagerty.com/media/maint...ors-vintage-corvette-from-death-by-fire/
2023 Miata RF Club
Chuck, Maybe you can post a picture of your Element fire stick please? I and other I'm sure may be interested to see how the included mounting clip works and how its mounted. Thanks for sharing this important safety information. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Per request from Gdads/Dan
The bracket is marginal/flops a bit but in the year+ I have had it installed is adequate.(2 be better).
The device works kind of like a flare, just steals the air where you aim for 50 seconds, and does not age out.
Chuck
Element 1
Element bracket
2023 Miata RF Club
Authorized Pest
Authorized Pest
Chuck, having the measuring tape in the images is a huge help. (Plus your comments.) So many times I need a reference of some sort. grin Thanks.
~ Peggy M
1949 Chevrolet 3804
Chuck
So it doesn't expire? If not that would make it extremely worthwhile!
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Thanks for the response and detail Chuck. I would have to agree that 2 clips would be a much safer mounting plan. I personally would be worried about it getting knocked out of the little clip and go rolling under foot while driving. big_eek
~ Dan
looking on their website
https://elementfire.com/collections/element-accessories
Seems they have multiple ie: better mount/bracket choices now (including a magnetic option which could be interesting)
Claim is “no service or upkeep” “no effective expiration”
2023 Miata RF Club
Great info and thanks for the link Chuck! thumbs_up
~ Dan
If you web search "broom handle clip", you will find many at your local hardware store, which many made of steel can be bendable to fit many different diameter items.
Craig
Will a fire extinguisher take the heat inside a truck in the hot summer?
I believe most extinguishers as mentioned above are manually activated, not automatically. Besides, how hot does it get in your cab, in the summer? Does it sit in a full hot sun?
Craig
I just watched a YouTube video of a guy testing out the Element Fire Extinguisher and it failed to put out a burn barrel fire and a small brush pile fire...not real sure how they would work for an engine fire when you really can't get to the bottom of the fire???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Like I said before - fire blanket.
For these fire sticks, I've seen similar up here too. My buddy, a fire prevention officer I talked to, his first reaction was what certification does it have - not sure if any of these newer types have been checked for efficiency or longevity by any certification laboratories in the United States or Canada. They hadn't been when I checked pre-covid.
Just some food for thought.
Personally I have a dry chemical on the passenger side also. I've got the GM heater but no fresh air panel.
I've also got a few extras on the outside, all functional, but they go with decor.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
On their web site, Fire Safety Stick has the certifications for all 5 types. 50 second and 100 second run models. I can discretely hide it in the truck and not ruin the look of originality.
I found and old 'Pyrene' extinguisher ( minus the toxic liquid ) with mount for $25 + shipping that fits the passenger kick panel and decor nicely.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
My bad, they hadn't been when I checked. Sounds like they’ve gone thru the process now. That's great, thanks for the clarification Chip O!
"Old Smokey'"
Here is the Elements extinguisher in my truck. It came with both the screw attached mount clip and the magnetic clip.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
I had an engine fire in another vehicle this last fall, and luckily had quick access to a fire extinguisher (only because it happened while pulling out of the shop). Needless to say I now have many more including in all our older vehicles. I found a nice small one for our 53. Second photo shows the aftermath of a small flare up. Just a few seconds and thousands in damage.
1953 Chevrolet 3100
I keep a white marine style one right in the cab corner on drivers side. Better than nothing.
For about $1K you can put a full racing system in for the engine compartment and the cab.
Moderator
Moderator
2 Offline
I myself have put out three different vehicle fires over the years using small fire extinguishers that I carry in all my cars and trucks.
Just by luck, none of those fires have been on any my vehicles.
The down side is, I never got reimbursed for the spent extinguishers from the people that owned the cars.
But it did give me a good feeling to save the day.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I've gone with the E100 Element. 100 seconds vs 50 seconds with the E50. Luckily never needed to use it.
Dennis
40 Chevy 1/2 ton
I'll throw a rock in the bush. Once my truck is together, I plan on putting a 15 gallon milk can filled with water on the bed. I have an Indian hand pump sprayer used for brush fires to connect and long enough hose. Is water a good idea or am I just dreaming?
Water on a gasoline fire is not recommended. Unless you have a fire pumper truck delivering the water at full mist. I doubt you hand pump sprayer would do the trick.
Get a fire blanket. It's a lot better than an extinguisher if you have a real fire that already going strong.
