7 members (Otto Skorzeny, J Lucas, dt235sd, Cosmo, jeffreyguy, Charles in CA, LAROKE), 132 guests, and 6 robots.
Topics128,107
Posts1,056,221
Members48,436
#1556755 08/30/2024 1:54 AM
I looked at a 1966 model (per owner) 292 today and it was orange in color. Was it orange from the factory? I thought they were the alpine green color.
The casting number is 3921370
1965 Chevy C10 Longbed Fleetside
As long as Walmart sells rattle can paint, who cares what color it was originally?
Chevy truck owners can of course be particular about the originality of their engine colors.
This is sourced from an informative blog about 1963 - 1966 292 engine paint colors: 292 Greenhttps://www.chevytalk.org/fusionbb/showtopic.php?tid/220319/
With some additional research, this can likely be corroborated.
1955 1st Series 3100
ol'55
I checked my shop and they are all red except a dark green one.
See post #16 for factory photo of 292 Green:
292 GREEN
ol'55
Thanks for the info. It appears I will be going with 292 green
You're Welcome,
Good choice!
ol'55
Friend of mine had a late year 1966 with a 292, built in TarryTown. He bought it with 25K on it about 10 years ago here in NH. It is super original and the engine is 0range.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Research from a few sources I found suggest the changeover from Green to Chevy Orange was model year 1967. Does that mean in late 1966 the changeover started? I don’t know.
You may be able to find and cite some more authoritative sources.
ol'55
I have a 1966 c10 with a 250. Under all the grease it’s orange.
1941 Chevrolet AL 3/4 Ton previous Portsmouth Ohio Fire Dept
1959 Chevrolet 3100
1966 Chevrolet C10 "Sunoco Truck"
1986 Chevrolet C20 Crew Cab 454 lowered 6"
1991 Chevrolet R1500 Suburban LS 6.0/4l80e swap lowered on Qa1 coilers
1994 Chevrolet c1500 lowered 2/4 on 17x11 Billets
2000 Chevrolet Silverado 1500 full custom on air bags.
From Jim Carter. See the notes at the bottom of the page.
Jim Carter Engine Paint Colors
ol'55
ol 55 thank you for the link. For 1965 and 66 truck with 292 it says green or dark gray. So either one would be correct.
