| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2023 Posts: 24 'Bolter | | 'Bolter Joined: Apr 2023 Posts: 24 | I’m wanting to replace the worn out front motor mounts on my ‘57 Chevy 6700. Are these the same mounts used on the other smaller chevy cars and trucks?
(v8 283)
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | I think there was a difference in the bird leg length between some models. Someone else will surely chime in to correct me if I am wrong.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | If it's just the rubber parts that are trashed, those may be the same as the smaller trucks, you could probably fabricate new steel parts if needed.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Your 6700 shares the same 7-1/2" long, 3/8-24 thread Stud with all of the little trucks...V8 and I6 all take the same stud. Mike B  | | |
