| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Hello, I have a '53 model 6400 2 ton truck. I wanted to replace the tires on this truck but I have a problem. I am told that this truck has "widow maker" / "suicide" rims on it and these rims are no longer allowed by law to be repaired or to have new tires installed on them. Does any one have sources for updated one piece style rims? I would have no problem in putting tubeless tires on this truck.
Best to all, Phil Stewart "plasticman" | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Dose it look like the wheels have an extra ring or two on the lip? If so then they are OK, they are lock ring wheels.
If you can't see how they are put together then it is probably in the very center, these are split rim wheels, and you should not play with them, and no one else who has a brain will either. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Good point Grigg I keep running in to tire shops that seem to think any tube type wheel is a widow maker and it’s just not so. If the tire and tube assembly comes off one side of the wheel via a removable one or two piece ring they are fine. Widow maker wheels split in the middle and are a bygone bad idea and should not be messed with. If you need to replace your wheels I would go to a tubeless radial for sure first find out what type of wheels fit your hubs, are they hub or stud piloted, what is the bolt pattern the number of studs and the bolt circle size, and the size of the center hole. Then decide what size tire you want to run, personally I would run the tallest tire that will fit without hitting anything, these trucks are really low geared and can use all the help they can get in that department. I changed my 56 from 9.00X22.5s to 10.00X22.5s and my 64 from 8 ¼X20 tube type to 10.00X22.5 tubeless radials both trucks started with about 38” tall tires and now have 40”tall tires on them this helped quit a bit with top speed and fuel mileage. Here is a link to Accuride’s website it was a big help to me all the tire shops told me the wheels that I wanted where antiquated and not made any more till I found a part number to give them and low and behold most of them even had them in stock so don’t give up based on what some tire shop tells you. http://www.accuridewheels.com/completeversion.pdf | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Hi everyone,
I've been reading the posts about the wheel and I'm wondering what year Chevrolet used the 2 piece wheels?
thanks Don | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Welcome aboard don stocker Good question I don't know the only truck I know of that has them today is a 62 F@rd has the same six lug pattern as my 56 Chevy though. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | SHOULD BE SHOULD BE. . . most of the 1.5ton and heavyer stuff is interchangable from brand to brand same chassie and diff's on most just depended on what sheet metal and engine you perfered. . .if you liked ford engine's you bought a 2 ton ford you liked chevy engine you bought a 2 ton chevy. . .the chassie's and diff's looked the same to me eaton/spicer/rockwell ect brand diff's and axle's and some transmission's. . .on most have seen from tran's on back same truck bell housing on forward is where the differences came in or the cab on top of it. . . mike
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hey Grant that wheel reference is great! Thanks for posting that.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Actually Steve that site had been brought to my attention by super Grigg!!! | | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | A thank you to Grigg, HevyHauler, OldSub, Don Stocker and 379MV6GMC-K3000 for the excellent contributions to my wheel question. I really appreciate you taking the time to answer my question. Best Regards to all. Phil "plasticman" | | | | | Joined: Nov 2004 Posts: 2,422 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,422 | Great, many thanks from me also. I too, have been looking for information on this topic. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Sep 2007 Posts: 5 New Guy | | New Guy Joined: Sep 2007 Posts: 5 | and thanks from me as well. my 41-46 bus has been a nightmare for the same reasons. wheels and tires.
thanks again alton
alton
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Hi Everyone,
Just got another truck home last night, '51 Chev 2-ton. Purchased it thru the Stovebolt classifieds. First thing I noticed as we wheeled it out of the trailer onto the loading dock was the 2 piece wheels. I understand from the posts here and also the article in the lastest Vintage Truck magazine that using these wheels is not a possibility. Is it possible to buy the other style wheels, meaning the ones with the split ring on the outer edge? I know I could also maybe purchase new wheels from Accuride. I've also read many posts about guys getting 19.5 motorhome wheels also. I'm not to the point with this truck that I'm sure how much money I want to spend yet, need to assess lots of things like will it even run. I do want the tires to hold air and also be safe to move around. What do you guys think is the most reasonable way to go? Anyone have a set of 6 split ring wheels they want to sell? Thanks Don | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have the 1951 originial rims and they are reliable and safe. I'm not sure which rims you have, but I'd check them before you ditch'em. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I just finished reviewing a tech tip on wheels and tires for our AD Chevy 1.5 and 2 ton trucks (and some 3/4 and 1 ton info too).
Give John and Peggy a few days to get it updated and we'll link to it here, until then just sit tight, as all your wheel and tire questions and options will soon be answered.
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Grigg you da-man I am waiting for Griggs' Book of Stovebolt fabrication and I want a signed copy.  | | | | | Joined: Feb 2013 Posts: 1 Moderated | | Moderated Joined: Feb 2013 Posts: 1 | Plasticman, what did you finally put on your truck? Interested because we are in the same situation. Thanks...
Others? | | |
