3 members (lumbersawyer, tclederman, 1 invisible), 70 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#155429 10/17/2007 3:51 PM
Gentlemen,
I have just purchased a 42 Chevy big bolt. It was listed and sold as a 1 1/2 ton but I'm not so sure. After arrival it looked alot like my current 3 ton. I measured the wheel base and it is 13', same as Bertha, I measured from the rear of the cab to the rear of the fram and that was 10 1/2', same measurement. There was a sticker on the door that reads GVW 8,000. I believe that is quite a bit more than the standard 1 1/2 ton.
The data plate is worn away except for the bottom numbers that are stamped.
HELP She is listed in the gallery under Dan Petra 42 medium and large trucks.
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
#155430 10/18/2007 12:57 AM
What are the numbers on the ID Plate. That will tell the story. Bertha looks more like a, 1 1/4, 1 1/2, or 2 ton truck to me. What's the ID tag on Bertha say. A 3 ton '42-'55 model GMC will be a 450 series. I noticed you have Bertha listed as a EC 283, which is a 280 series, 1 1/4 ton truck. All of the above, stands true, if these trucks are U.S. built.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#155431 10/18/2007 3:43 AM
I'll check the plates in the morning. Are you going to Fayetteville on Sunday? Bertha will be there....got lots to do on the other one. I cannot find anything on the data plate in the other truck.
Bertha was by another truck which was a 1940 US built 1 1/4 ton. There was a noticible difference in the wheel base. Bertha was longer by almost 4 feet.
Matt
#155432 10/18/2007 4:01 AM
BTW, Bertha is a GMC built in Canada. She was a grain truck with a dump bed.
#155433 10/18/2007 4:02 AM
Would measuring & counting leaf springs (all suspension parts) indicate what weight class it is? maybe the previous owner re titled it under a lower weight class to save $$ on auto insurance.
#155434 10/18/2007 4:10 AM
What's happ'nin in Fayetteville.
Spanky Hardy
1950 GMC 250 1-Ton
#155435 10/18/2007 6:31 AM
Packhorse32 is havin a truck show.....
#155436 10/18/2007 12:41 PM
Bertha is a 2283 EC with 11,000 GWV. The data plate on the other truck is unreadable. All I can make out is 9MS42, and next to that 288496.
#155437 10/19/2007 2:33 AM
11000lb. gvw., would make Bertha a 1 1/4 ton. 1 1/2 ton is 14000lb., 2 ton is 16000lb, & a 3 ton would have a gvw, of 19500lb.
Spanky Hardy
1950 GMC 250 1-Ton
