2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | Gentlemen, I have just purchased a 42 Chevy big bolt. It was listed and sold as a 1 1/2 ton but I'm not so sure. After arrival it looked alot like my current 3 ton. I measured the wheel base and it is 13', same as Bertha, I measured from the rear of the cab to the rear of the fram and that was 10 1/2', same measurement. There was a sticker on the door that reads GVW 8,000. I believe that is quite a bit more than the standard 1 1/2 ton. The data plate is worn away except for the bottom numbers that are stamped.
HELP She is listed in the gallery under Dan Petra 42 medium and large trucks. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | What are the numbers on the ID Plate. That will tell the story. Bertha looks more like a, 1 1/4, 1 1/2, or 2 ton truck to me. What's the ID tag on Bertha say. A 3 ton '42-'55 model GMC will be a 450 series. I noticed you have Bertha listed as a EC 283, which is a 280 series, 1 1/4 ton truck. All of the above, stands true, if these trucks are U.S. built. | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | I'll check the plates in the morning. Are you going to Fayetteville on Sunday? Bertha will be there....got lots to do on the other one. I cannot find anything on the data plate in the other truck. Bertha was by another truck which was a 1940 US built 1 1/4 ton. There was a noticible difference in the wheel base. Bertha was longer by almost 4 feet.
Matt | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | BTW, Bertha is a GMC built in Canada. She was a grain truck with a dump bed. | | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | Would measuring & counting leaf springs (all suspension parts) indicate what weight class it is? maybe the previous owner re titled it under a lower weight class to save $$ on auto insurance. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | What's happ'nin in Fayetteville. | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | Packhorse32 is havin a truck show..... | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | Bertha is a 2283 EC with 11,000 GWV. The data plate on the other truck is unreadable. All I can make out is 9MS42, and next to that 288496. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 11000lb. gvw., would make Bertha a 1 1/4 ton. 1 1/2 ton is 14000lb., 2 ton is 16000lb, & a 3 ton would have a gvw, of 19500lb. | | |
