3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
rad
Offline
Want to add power steering on my 49 truck 3100. Has a 3” drop axel as well as a 3 on the tree I want to keep. What are my options?
rad, Your question will get the best answers in the HiPo Shop forum so it's been moved for further conversation and help. I am sure other Bolters will be along soon too join the discussion. smile
Last edited by Gdads51; 08/01/2024 3:11 AM. Reason: corrected location to coincide with correct forum
~ Dan
1951 Chevy 3 window 3100
How handy are you? The prius electric conversion uses the existing column/steering box.
EPAS might have a kit for that truck, though I don't know offhand if it will fit below the three on the tree linkage.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I have the EPAS Performance kit for my 53 3100. I would give them a call about the column shift. After looking at the FSM I think you would have to make a new rod and dog leg it around the unit. I can give you any measurements you need. It's still in the box. I put a 15.5" ring on my steering wheel. I'm also putting a Howe 1:1.5 steering quickener on mine.
If you want to stay hydraulic then the set up off aToyota 4wd (late 80's) is the easiest but I like the EPAS set up.
Evan
rad
Offline
Thanks. Will investigate
