6 members (Ridgeback, Gdads51, carbking, Jon G, 55shaker, 1 invisible), 61 guests, and 2 robots.
Topics128,268
Posts1,058,391
Members48,485
Anyone know what thickness the rubber window setting tape for the vent window is? And where can I find 3 inch wide rubber tape for the vent window install? All I am finding is 1.5 inches which is not wide enough to cover the latch. Thx
[email protected]
1964 Chevy C10 fleetside LB original/unrestored
1966 Chevy C10 stepside SB restomod in progress
1970 Chevy C20 fleetside LB restored
If you take a look at the below page from the 1960-66 FAM, it shows 4 different "Filler" setting tape thicknesses (4 different part #'s) depending on the glass thickness measurement. I found 3 different thickness tapes offered from various vendors - 1/32", 3/64" and 1/16" thick tapes, but as you mentioned none over 1-1/2" wide. You may need to check out a local glass company to see if they might have the extra wide tape in the thickness you need. Good luck and let us know what you figured out please. smile
~ Dan
1951 Chevy 3 window 3100
As mentioned, I ran down to my local glass store and they looked at my need and produced what was needed. In my case, very easy and I was happy to use local business.
~ HB
1962 Chevrolet C10
1962 Suburban
