7 members (Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, Phak1, 1 invisible), 44 guests, and 2 robots.
Topics128,089
Posts1,056,009
Members48,430
#1553961 07/29/2024 1:26 PM
Y
Y Offline
Doing a disc brake conversion on my 1952 truck. The hub is not riveted on. How do I get off
1952 3100
back yard wrench turner
Drive the lugs out. You will need to replace them anyway.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Crusty Old Sarge
Crusty Old Sarge
Youngster, this would also be a great time to upgrade to tapered roller bearings. Tapered bearings can handle a lot more side load than the original ball type.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Y
Y Offline
Do you think the lug studs are attaching them. Tried pressing them out in a vise but they don’t seem to move. Maybe a press will work better. I do have new roller bearings, seals etc.
1952 3100
Your hub and drum looks to be earlier than 1952. Looks more like 1947-50 Huck front brake drums??? Check out this 2019 conversation with pictures that shows the same drum/hub setup you have. Guidance provided in that thread with a referral to the Shop manual on how to separate the hub and drum. Hope this is helpful. smile
~ Dan
1951 Chevy 3 window 3100
Y
Y Offline
Thanks for the info. I am just going to order new hubs. I figure by the time I rework the old ones for my conversion I am better off just having everything new. I can save the old drum and hubs. Yes I do have huck brakes in the front. A lot of weird modifications made by previous owner. I think they thought all 47-54 parts are interchangeable. Most people don’t know there are differences over the years.
1952 3100
The lug studs are swaged into a tapered recess in the hub flange. There used to be a cutter we would use in a drill press to cut away the top of the lug stud and release the swage, and drive the studs out with an air hammer. If you don't have a swage cutter, it's possible to force the stud out with a press, but use some sort of support on the back side to prevent warping the hub flange.
... and when you put everything back together don't use the factory specs for tightening the spindle nut (with ball bearings) with your new roller bearings.
A lot of the Japanese compact pickups (Nissan, Toyota, Isuzu, Mazda, etc.) used the same 6 lug wheel bolt pattern as early Chevy pickups. It's fairly simple to adapt hubs and disc brakes from one of those vehicles to an early Chevy front spindle.
I agree. I just had one of my front hubs off to replace a seal and repack the bearings and they are definitely different than your picture. The drum on '51 and later (Bendix brakes) attaches on the outside of the hub, but it appears that your brake drums are attached inside of the hub flange.
I like Jerry's suggestion. Toyota copied quite a bit of GM's parts, including the 235 engine (with some slight variations.)
I bought new hubs when I converted to roller bearings. They sell them together. They offer two choices. Drum or disc.
There are disc conversion kits offered by several aftermarket suppliers that use a 6 lug
either 11" or 12" one piece rotors that come with tapered bearings. Some are configured to
use stock wheels as well.
Fred
