7 members (Leo, Goach2, UtahYork, klhansen, JoeDude, pauld, Wayne67vert),
129
Mod | | | Forums66 Topics128,185 Posts1,057,290 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 3 Junior Member | | Junior Member Joined: Sep 2007 Posts: 3 | I have a new project!A '37 1 1/2 ton and would like to identify the engine etc. as well as original equip. and set-up. My truck has a plate on the firewall that says GMC T-16 B, Chassis #28782 straight rating 11000 lbs. It is a duelly with a flathead 6, four speed w/ 2 speed rear.The casting # on the block is GM 408004-3, the registration states that the engine # is T49470,, but I havent confirmed that that coincideds with anything, most of the info I have been able to find is Chevy specific... Any help or leads will sure be welcome, it's a long way to go from here... Thanks, Cheers, | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | welcome to stovebolt.com, post some pictures of your project when you can should be some folks with your info before the weekends over. you can also try www.inliners.org and www.oldgmctrucks.com | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Welcome aboard boattruck. The T-16B has a wheelbase of 157 inches. The original engine is a 230 cu in Oldsmobile. I show a block casting number 408003. The engine number will be at the top front driver side just below the head, stamped on a machined boss. The T indicates a truck engine which had a few differences from the passenger engine. Primarily cam, carb and no vacuum advance on the distributor. | | |
