5 members (frogfarmer, JW51, treegrower, Charles in CA, 1 invisible), 47 guests, and 3 robots.
Topics128,074
Posts1,055,910
Members48,429
#1553653 07/26/2024 12:19 AM
I
I Offline
I am working on a 1950 chevy 3100. I purchased a retrosound unit (so I could bluetooth music mostly). The original dash has some other holes present (see image). Anyone know of a bezel for that era? I always thought the knobs came through the dash and that's it. Maybe my truck was modified at some point. Any insights would be greatly appreciated!
INFARMGUY #1553661 07/26/2024 1:36 AM
Below is a screen grab of a dash panel with the original radio openings (center rectangle and 2 close in Control knob holes). Your dash got modified at some point. An original radio would have filled the center rectangle and 2 closer holes that center on the middle opening.
Is the radio displayed in the picture the one you intend to use?
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1553664 07/26/2024 1:54 AM
I
I Offline
Gdads51--makes sense! I had feared it may have been modified I'd like to use this one, but I am also open. I could also fill in the incorrect holes and go that route.
INFARMGUY #1553670 07/26/2024 2:13 AM
Are you able to move the knobs on the radio inboard so as to use the innermost holes in the dash? I'll bet you can. That radio looks like it was designed for your truck. That would provide a more correct look. Then you can fill all of the extra holes.
INFARMGUY #1553672 07/26/2024 2:29 AM
INFARMGUY, Looks like you have a bunch of extra holes in your dash. The one above and centered on the radio may have been used to mount a “stop light viewer”, especially if your truck had/has an exterior sun visor.
~ Dan
52Carl #1553689 07/26/2024 5:33 AM
Professional procrastinator
Maybe do some measuring before you decide. To my eyes, the inner set of holes look to be off. They should be equal distance from the center opening and that right side sure looks closer than the left. I can post edge to edge measurements in the morning.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
INFARMGUY #1553698 07/26/2024 12:32 PM
Where you have the radio knobs looks to be correct. I installed a retro sound radio in my truck too.
1947 3600 Chevy
INFARMGUY #1553706 07/26/2024 1:59 PM
Twin Jimmys is right on the holes you used for your radio. My comment above on using the inner holes is in error - sorry! Was looking at the pic on my phone, so I'm going to blame it on the silly small screen thingy - lol! not me
~ Dan
INFARMGUY #1553715 07/26/2024 2:36 PM
Go to arts and crat store and buy a sheet of thin plastic board. Cut to cover the area and secure with radio knobs.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
INFARMGUY #1553727 07/26/2024 3:49 PM
The lighting in the garage is not the best at this time of day. More importantly, my eyes are not as good as they used to be. Add to that, my prescription reading glasses are playing hide n' seek. The two holes are the same distance from the center opening. It looks to be 15/16" from edge to edge between holes. That way we know for sure. Not that it really matters as your radio is in and looks like a good fit, just a few extra holes. Get creative or get to filling and painting!
INFARMGUY #1553728 07/26/2024 3:57 PM
Odd with the extra holes.
I still have the radio delete plate but that only matches the large center square and two knob holes, which won't help you.
Too late for welding up the extras. Yes, a thin sheet of shapable plastic and a dash color match coat would be the easiest.
I just installed my classic radio with blue tooth and extras. I paid $350 for it 3 years ago and they want over $700 now.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
INFARMGUY #1553748 07/26/2024 10:55 PM
What baffles me is all the other holes. The 4 smaller holes are not located exactly from each other, and also the two larger holes near the square opening are not in the same exact location from the edge of the square opening. Yes for shapeable plastic or metal attached to the inside of the dash and then fill in the holes. Do you have extra interior paint?
Craig
INFARMGUY #1553753 07/26/2024 11:50 PM
Wonder if it was an old farm truck cab that had fans mounted on the dash. One for pass, and other for driver. 2 different fans would maybe have different holes.
Chip
'Rusto-Mod'
#1553755 07/26/2024 11:54 PM
Looking to fill without welding, try All Metal. It’s meant to replace the old lead on body seams. It’s called other things also. Then sand, prim and blend… or shoot the whole dash. I’m terrible at blending.
Welding would be more permanent.
Chip
'Rusto-Mod'
Moderated by  ndkid275, Phak1
