Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
9 members (frogfarmer, 66flea, DoubleB, moparguy, ShopRag, Bill Hanlon, Wheelie, Dakota Bob, 1955 1 Series), 189 guests, and 1 robot.
Topics128,292
Posts1,058,590
Members48,492
U
U Offline
Updated photos on my Big Bolt. I just made my trans mounts for my 48. I got help from Stovebolt member 48bigtrucks, Thanks for the photo Scott! I still have to finish powder coating the second mount as well as the front engine mounts.
http://rides.webshots.com/photo/2416401120040363269fQGViK
[img]http://rides.webshots.com/photo/2832708280040363269EfjrGJ[/img]
[img]http://rides.webshots.com/photo/2310086500040363269RUATuA[/img]
[img]http://http://rides.webshots.com/photo/2793173860040363269DcNyFZ[/img]
Good deal, I forgot all about them. Put a small piece of conveyor belt between the mount and the cross member for a little dampening and you'll be good to go,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
U
U Offline
Thanks Scott i'll do that. Hey, what angle is your trans. I read that it should not be zero degrees and it should not exceed 4 degrees. Is this the angle of the output shaft on the trans or the drive shaft? What degree did you make yours at?
I set my frame level on jack stands and set the engine/trans at 6 degrees. Then I installed the rear at 6 degrees. I didn't have any body parts or any other heavy stuff to preload the suspension to adjust for rake, but I figured in 2 degrees for rake to hopefully end up with the desired 4 degrees of pinion angle when the truck was fully assembled. It's not all that important to go more or less than 4 degrees, just that the trans and the rear end are at the same angle,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
