9 members (66flea, Rosco, Dakota Bob, 1955 1 Series, Shaffer's1950, dt235sd, Otto Skorzeny, KEVINSKI, 1 invisible),
195
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,291 Posts1,058,588 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Good deal, I forgot all about them. Put a small piece of conveyor belt between the mount and the cross member for a little dampening and you'll be good to go, Scott | | | | | Joined: Dec 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 60 | Thanks Scott i'll do that. Hey, what angle is your trans. I read that it should not be zero degrees and it should not exceed 4 degrees. Is this the angle of the output shaft on the trans or the drive shaft? What degree did you make yours at? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I set my frame level on jack stands and set the engine/trans at 6 degrees. Then I installed the rear at 6 degrees. I didn't have any body parts or any other heavy stuff to preload the suspension to adjust for rake, but I figured in 2 degrees for rake to hopefully end up with the desired 4 degrees of pinion angle when the truck was fully assembled. It's not all that important to go more or less than 4 degrees, just that the trans and the rear end are at the same angle, Scott | | |
