1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I have a good 292 core I would like to rebuild for my '49 1 1/2 ton. Intended use will be mostly local with a grain/cattle box with maybe one or two trips a year to the livestock auction yard 90 miles away. Except for the trips to auction, it will seldom see speed limits over 45 mph and a lot of gravel roads. Originally I had visions of lpg pistons, rv cam, 4bbl intake and dual exhaust. Given the trucks intended use, a couple things have me re-thinking that vision.
-First, with higher compression and a hotter cam, would I trade durability and reliability for power gains that may not do that much for a large truck?
-second, would the cost of lpg or custom pistons and performance cam be worth the expense in my application.
I'm now thinking for a truck that will be a work horse, I'll stay stock internally, adding only a 2bbl intake, cast iron dual exaust manifolds and a HEI distributor. That should make a pretty dramatic change from the stock 216. Probably the transmission and two speed axle will stay stock where they are in good shape. I may run taller drive tires to help the axle ratio a little. I want the truck to earn it's keep and still outlive me.
I getting ready to send the block to the machine shop and collect parts so any feedback would be appreciated.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I have very little knowledge in "building" a 6 cylinder, but will say that a stock 6-292 is a real good engine. In a truck, I actually prefer a 292 over a small block V-8. I had a 292 in a '64 C-30 and it had plenty of power. It was all stock, except for the exhaust and a slightly shaved head as they found the head a little warped when I sent it out for a valve job. Fully loaded at 10,000 plus pounds was no problem going uphill. You will have more gears to pick from than I did, which will make it even better.
For the exhaust, I used a GMC V-6 straight thru muffler. Letting these engines breathe better will add to the power.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Speaking about cams, I got mine from Clay Smith Cams. Custom grind for only $200 bucks! You tell them your specs. and what your application will be. So you want low-end torque, they will do it no problem to what ever you want. I highly recommend them
58' 3200 235 3-speed/OD
| | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I have a basically stock 292 in my 47 and like it alot. It would run 45mph real nice and I could run 55 but it was reving more than I liked. I think you well be pleased with it, for all your plans, I now have a overdrive and can run 65mph. But I dont like those speeds in the truck and about 60 is where I like it out on the freeway. Still around town I like running at about 35 with it, good luck with yours. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | just drop a 5.9L cummins in there. . .
12 valve 5.9L/5spd manual. . .
24 valve 5.9L/6spd manual. . .
With today's gas prices running a gas engine in anything heavyer than a 3/4 ton is a waste of money. . .
with the cummins diesel in that truck you would get 12-16 mpg easy loaded maybe 17-19 empty. . . the 292 might get 9mpg empty at best an 5mpg loaded and it ain't going to have any power in the hill's with a load. . .
I'm a die hard but even i'm updateing. .
Mike. . .
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | If you are getting rid of the 216, I would be interested in taking it off your hands for a reasonable price.
Matt | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Originally posted by 379MV6GMC-K3000: the 292 might get 9mpg empty at best an 5mpg loaded There may be some difference in a 1 1/2-Ton, but my 1-Ton got about 15-16 MPG empty and not that much less fully loaded. But I will say my mileage seemed to be higher than normal for some reason. I still would be hopeful on about 12 in a 1 1/2 Ton. (Fully tuned and with a Hi-Po muffler tho)
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 379MV6GMC-K3000 .... "just drop a 5.9L cummins in there. . ."
...darn, you make that so sound easy. | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | Originally posted by 53moneypit: 379MV6GMC-K3000 .... "just drop a 5.9L cummins in there. . ."
...darn, you make that so sound easy. yea i do don't I . . . i'm a rotten kid ! i've done it to a set of ford's, a 1961 F-500 and a 1965 F-700 both had inline 6 gas engine's was almost a drop in bolt up swap tank's and go easy. . .Almost! but it wasn't all that bad. I Built both truck as a pair for about $7,500. . .I paid $500 for the 2 ford trucks to begin with, my oldman bought the set about 2 year's later for $12,000...  he's a heavy truck collector he's got a much bigger bugget than i as he own's his own land scapping and excavating company so most of his collector's are an " advertising " exspense :whistle: . . . his office is basicly a show room you gotta walk past all the truck's to get to the counter. . . uniform paint company logo on each door who's going to argue i guess. . .
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | Your 292 sound's like a fine engine i like them i would run 500CFM 2 bbl on it with the HEI ignition,open up the exhaust and see how it dose for yea. . .
once you start changing compression and cam shaft's reworking head's to get more pulling power than your better off going to a diesel engine at that point cost will close to the same just longer engine life more power. . .
Whitch is why i started off with cummins diesel sugestion. . .
Mike
| | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | The Cummins would be nice but for the same money I could probably just buy a used trailer to pull behind the '01 Dodge diesel pick-up I allready have. Maybe when the Cummins wears out all the Dodge parts, I'll have a donor. once you start changing compression and cam shaft's reworking head's to get more pulling power than your better off going to a diesel engine at that point cost will close to the same just longer engine life more power. . . Actually this is why I'm thinking of staying stock internally. I could live with the 216 but it's getting tired and it falls on it's face fast on the hills . Thanks for the feedback, everyone.
Joe McNeel
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | there yea go wear out the New truck put the power plant in the old one. . .I wish you the best of luck. .. . now if i could only fine some decent tire's of my truck's. . .
Mike
