| | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | I have an intake and exhaust manifold for a 216 that I am trying to find what year it might be. I've had no luck on internet so figured I would ask here. Exhaust number is 3885888. Intake is 3835527. Thanks Grady. | | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Grady, My Chevy Inline 6 Engines resource book shows an exhaust # of 3885388 for 1950-53 216. It doesn't show a "3885888" and that 3rd from last 8 in yours should actually be a "3" I think. The intake 3835527 is a match for 1950-53 216 also. If you do a bit more looking on the manifolds, there should be a date casting number starting with a single letter and a couple of numbers. If you can find them, post them here and we can decode what they mean.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | Ok on intake is a L70 and also a 22. On exhaust is L80 and a 5. The 22 and 5 are on opposite side of the other numbers. The reason I'm researching this is because I have a rebuilt 51 motor. And I wanted to make sure it would work on it. | | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | And yes the other number was a 3. Thanks, Grady. | | | | | Joined: Jan 2022 Posts: 2,479 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,479 | L is December (or maybe November, I can't remember if they used I). A = January, B = February, etc. 7 is the 7th day of the month. If the day of month was 10 or more there would be 2 digits. 0 is the last digit of the year. 216 engines were built in 1940 and 1950.
This manifold did not leave the factory in your truck If your truck is a 1949 model.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | | | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | The motor in my 49 isn't a 49 motor. It is a long story about my 49. I have learned alot from you all on here. | | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Grady, If these are to go on your 1951 "216", they will work just fine.
