5 members (Peggy M, Hush, MNSmith, Phak1, tclederman), 148 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#1552419 07/12/2024 12:21 AM
I
I Offline
I have this air cleaner (see attached) I've always thought it to be an oil bath, but I can't seem to figure out how to "load" the oil. It doesn't separate to reveal an internal bowl like some I've seen. I want to use it on my 216 but need some instruction!
Thoughts?
B Online: Content
That is not an oil bath filter. It is an oil wetted filter. Instructions for the same filter in a GMC truck say
I
I Offline
Thanks!! Does anyone recommend trying to run an appropriately sized paper element in place of the oil-wetted steel?
B Online: Content
I use one. I couldn't find a short enough filter looking through Fram's catalog, so I had to extend the bolt that holds down the lid. I'll go out in the garage and get the number from the filter in an hour or two.
B Online: Content
Third picture shows the extended lid hold down bolt.
I
I Offline
Thanks, Bill! That's exactly what I need! Appreciate you!
I
I Offline
Bill--Got the WIX filter you suggested and made a new threaded rod---works great!
Does the Fram CA140 also work?
1949 3100
B Online: Content
I've used both. The threaded rod needs to be a little longer to make up for the slightly taller filter element. I had mine welded in place so I didn't have to worry about loose hardware falling through the carb.
Thanks!
1949 3100
