2 members (55shaker, 1 invisible), 55 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#1552419 07/12/2024 12:21 AM
I
I Offline
I have this air cleaner (see attached) I've always thought it to be an oil bath, but I can't seem to figure out how to "load" the oil. It doesn't separate to reveal an internal bowl like some I've seen. I want to use it on my 216 but need some instruction!
Thoughts?
That is not an oil bath filter. It is an oil wetted filter. Instructions for the same filter in a GMC truck say
I
I Offline
Thanks!! Does anyone recommend trying to run an appropriately sized paper element in place of the oil-wetted steel?
I use one. I couldn't find a short enough filter looking through Fram's catalog, so I had to extend the bolt that holds down the lid. I'll go out in the garage and get the number from the filter in an hour or two.
Third picture shows the extended lid hold down bolt.
I
I Offline
Thanks, Bill! That's exactly what I need! Appreciate you!
I
I Offline
Bill--Got the WIX filter you suggested and made a new threaded rod---works great!
Does the Fram CA140 also work?
1949 3100
I've used both. The threaded rod needs to be a little longer to make up for the slightly taller filter element. I had mine welded in place so I didn't have to worry about loose hardware falling through the carb.
Thanks!
1949 3100
