0 members (), 116 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1552114 07/09/2024 12:07 PM
What is the dry weight of a 261 complete including flywheel pressure plate and bell housing. I need to calculate shipping.
Thanks Red
aka (Shade Baby)
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Shade Baby #1552118 07/09/2024 1:06 PM
Red, Snapshot below taken from the 1955 2nd Series Chevy Truck Data PDF shows the dry weight of the 261 with clutch (assumes that's with flywheel, but doesn't say for sure if with bell housing) = 616 lbs. If you want a cushion on weight estimate, add 25 lbs for the bell housing and you should be close enough. smile
~ Dan
1951 Chevy 3 window 3100
Shade Baby #1552154 07/09/2024 7:58 PM
That baby is heavy thank You.
Red
"Back In Time"
Follow in the DITY
Shade Baby #1552156 07/09/2024 8:07 PM
By the time you add a forklift pallet to carry it, figure on about 700 lbs., fan to bellhousing. Most shippers like Blue Lane Freight (Fastenal) insist on "dry" cargo- - - - -no fluids to leak. Blue Lane, which is owned by Fastenal, ships palletized freight from one Fastenal store to another, at pretty reasonable rates.
