3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 213 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 213 | Going to look for a speedo cable for my custom build. 700R4 transmission with mechanical conversion and stock 0-90 speedo. I'm measuring about 72" to route it as far away from exhaust. To help with heat and durability, which should I look for...metal or plastic outer? And any GM speedo side fitting and 200-700 trans side, correct? I've searched a bit and can't find much on sizes other than "fits GM". They just list stock lengths and no fitting sizes. The early GMs had a tab on the trans side cable I've seen.
Any info much appreciated.
Thanks. Chip
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There must be a speedo shop near you, Deluxe Speedo, Denver, CO, if not.
Ed
| | | | | Joined: Jul 2021 Posts: 213 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 213 | Local only newer factory fixing on modern gauges and electrics. Just looking for some input about past experiences with repop metal or plastic. Good or bad. I think I'll just get a plastic one from Jegs. They have a 73". Grease the hell out of it before install. Can't find a metal jacketed that long, unless I want to spent $200 for Lokar.
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The metal ones are much more flexible & easier to work with. Classic Parts caries them both ways but I'm not sure about the length.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2020 Posts: 1,954 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,954 | ATP Automotive ATP Y-804 Speedometer Cable $7.21 works for all my trucks Longer
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | Chip, Summit carries the cable Guitplayer mentioned ATP Y804 if that helps. Found it also on Amazon and a bunch of other FLAPS sites.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | Thanks for the correction Mike!
| | | | | Joined: Jul 2021 Posts: 213 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 213 | Found this one at Jegs, being they had something else $20 cheaper than others I wanted. https://www.jegs.com/i/OER/691/6478128/10002/-1Thanks for the responses. Chip
Chip
'Rusto-Mod' '51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock '92 GMC Sonoma GT #15 of 806 '91 GMC Sonoma GT Extended cab 1 of 1 Trucks, Trucks.....and more Trucks | | | | | Joined: Dec 2020 Posts: 1,954 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,954 | The 63 is plenty long enough. At least for my trucks. It'll reach a 700R4
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Classic Parts metal housing cable is 72" long.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | Thanks everyone for offering to help Chip out.  Sounds like he has the bull by the horns. Come back and let us know how the new cable works out Chip.
