4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#1551907 07/07/2024 9:21 PM
Going to look for a speedo cable for my custom build.
700R4 transmission with mechanical conversion and stock 0-90 speedo. I'm measuring about 72" to route it as far away from exhaust.
To help with heat and durability, which should I look for...metal or plastic outer?
And any GM speedo side fitting and 200-700 trans side, correct?
I've searched a bit and can't find much on sizes other than "fits GM". They just list stock lengths and no fitting sizes. The early GMs had a tab on the trans side cable I've seen.
Any info much appreciated.
Thanks. Chip
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
Chip O #1551910 07/07/2024 9:28 PM
Crusing in the Passing Lane
There must be a speedo shop near you, Deluxe Speedo, Denver, CO, if not.
Ed
Chip O #1551955 07/08/2024 2:43 AM
Local only newer factory fixing on modern gauges and electrics.
Just looking for some input about past experiences with repop metal or plastic. Good or bad.
I think I'll just get a plastic one from Jegs. They have a 73". Grease the hell out of it before install. Can't find a metal jacketed that long, unless I want to spent $200 for Lokar.
Chip
'Rusto-Mod'
Chip O #1551966 07/08/2024 9:32 AM
Riding in the Passing Lane
The metal ones are much more flexible & easier to work with. Classic Parts caries them both ways but I'm not sure about the length.
George
1972 Chevy c10 Cheyenne Super
Chip O #1551970 07/08/2024 11:43 AM
ATP Automotive ATP Y-804 Speedometer Cable $7.21 works for all my trucks
Longer
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Chip O #1551973 07/08/2024 12:50 PM
Chip, Summit carries the cable Guitplayer mentioned ATP Y804 if that helps. Found it also on Amazon and a bunch of other FLAPS sites.
~ Dan
1951 Chevy 3 window 3100
Chip O #1552080 07/09/2024 1:13 AM
Dan/Guitplayer, the cable you linked/mentioned is only 63" long.
This one is 73"
https://www.summitracing.com/parts/amd-w-872
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Chip O #1552083 07/09/2024 1:29 AM
Thanks for the correction Mike! smile
~ Dan
Chip O #1552096 07/09/2024 2:59 AM
Found this one at Jegs, being they had something else $20 cheaper than others I wanted.
https://www.jegs.com/i/OER/691/6478128/10002/-1
Thanks for the responses.
Chip
Chip
'Rusto-Mod'
Mike B #1552111 07/09/2024 11:05 AM
This one is 73"
Mike B smile
The 63 is plenty long enough. At least for my trucks. It'll reach a 700R4
~ BD.
Chip O #1552126 07/09/2024 3:26 PM
Classic Parts metal housing cable is 72" long.
George
Chip O #1552199 07/10/2024 12:17 AM
Thanks everyone for offering to help Chip out. thumbs_up
Sounds like he has the bull by the horns. Come back and let us know how the new cable works out Chip. smile
~ Dan
