2 members (Gray_Ghost, Joe W), 211 guests, and 2 robots.
Topics128,108
Posts1,056,231
Members48,436
#1551657 07/05/2024 6:39 PM
8
nothing beats a try but a failure
8 Offline
The first valve adjustment was after the third run. Each run was 30 minutes. I posted my findings. There were some large gaps in the intake. #6,#4 and #1 were high. #5 was .002”. #2 was right on the money. The exhaust side numbers were close to the shop manual numbers of possibilities.
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
New cam and lifters, or used ones? It's possible some of the initial adjustments were done with the cam slightly out of position on some cylinders. Do a forum search for "companion cylinder valve adjustment"- - - -I've burned through several billion electrons over the past 20-something years describing that procedure.
