Brrrr
place holder
5 members (Otto Skorzeny, baldeagle, Woodcmiami, Gdads51, Wisner955), 122 guests, and 4 robots.
Topics128,274
Posts1,058,425
Members48,485
#1549585 06/14/2024 10:31 PM
I am slowly working on cleaning up my engine compartment along side the rest of the disaster I call a life and ended up with a new air cleaner.
I have an opinion, but I am curious what other people think of these two choices.
(Ignore the wrong battery, overly long air cleaner stud, and WIP wiring)
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
They both look good... are the filter elements on-the-shelf items? Is one filter twice the price of the other one? Your choice. The larger one may look better on that V8.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
7
7 Offline
I vote for the big one.
Both filters are cheap and off-the-shelf.
The 10" one looks too small and sits too high in my opinion. The 14" one is more typical, but feels too big. I like how it sits lower though.
This looks good on paper, but at 12x8.5 I feel like it will look off as well. The oval filters are harder to come by as well, which is a pretty significant con.
I think a 12" with a drop base (like the 14" one here has) would be perfect, but those don't seem to be readily available.
At this piont I am leaning toward the 14" one.
Professional procrastinator
I like the larger one.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
O Online: Content
I also vote for the big one in the 2nd photo.
1950 Chevrolet 3100 (Ol' Roy)
Just to be contrary, I like the look of the smaller one, but your engine will like the larger one.
AD Addict & Tinkerer
My vote is for the larger one!
Phil
Project Journals
Stovebolt Gallery Forum
Crusty Old Sarge
Crusty Old Sarge
I have the oval style on my 327, it was purely for the look. The filter elements are available but I opted to go with a K and N.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Being the pot-stirring contrarian that people think I am (they're right, BTW) I'm going to say "none of the above"! You need an air cleaner element about two inches taller to assure there won't be any restriction to airflow. Use the biggest diameter filter that will fit comfortably, and make it at least three inches tall.
These are just the filters the air cleaners came with. I will get a taller filter of whatever shape I end up with.
The question was re: the air cleaner, not the filter element.
Former Workshop Owner
I like the bigger one.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
That looks a little short to me but I'm no expert. What ever you run I would highly recommend a K&H filter. They are pricey but it's one and done and cleanable. They are known for their flow. The air cleaner is no place to scrimp. JMHO
It is interesting that you say that about K&N filters, because every test I have seen done by someone other than them says they both flow and filter worse.
We ended up deciding to go with the 14" housing and a 3" tall filter.
As I said I'm no expert but everyone I know that races with an air cleaner uses them. Flow and filtering ability have always been a trade off. I don't understand how they could be worse at both.
Last edited by Peggy M; 07/22/2024 11:11 PM. Reason: Remove quote - not necessary ;)
Here is one of the better test examples:
https://www.project200.com.au/dm-iso5011/
As you can see, the K&N is much, much worse than most anything else at filtration. When it is brand new, the K&N does flow better, but it rapidly degrades with use.
For intermittent race use where you are exposing it to minimal overall use, the K&N is probably ok. For something on the street where you are putting on a lot of miles/runtime, I would not recommend it.
Thanks for the info.
Last edited by Peggy M; 07/23/2024 3:07 PM. Reason: Remove quote - not necessary ;)
