0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#1549266 06/11/2024 3:44 AM
Hello, can anyone identify this pto and the adapter that's bolted to the GM SM420 trans? Thanks'
1959 Chev Napco 4x4 3100 w/235cu
Looks like a gear reduction unit to me...spin the input shaft and count rotations on the PTO to determine what the ratio is.
Facing forward I would assume it drives a mechanical winch, but I'm just guessing.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Maybe there is some helpful information from this web source ??? wink
~ Dan
1951 Chevy 3 window 3100
The PTO is forward facing for a winch. Problem is that the bell housing cross member is in the way. The 30 degree adapter re-positions it so the line line passes underneath. The PTO appears to be a Dana/Spicer(from research). I'm trying to identify the adapter now so I can attempt to locate one. No luck so far.
Gdads51 #1549446 06/13/2024 6:15 AM
Thanks for the Muncie site. I will call them tomorrow.
H Online: Content
That PTO closely resembles one I had on a heavy haul wrecker. It powered a 35 ton belly winch, and it had forward and reverse direction capability. I believe the fwd and rev ratios were slightly different due to different tooth count gears inside the PTO. I don't remember a PTO brand name or part number- - - -I managed that wrecker service in the late 1990s.
Finding an adaptor that fits a transmission that hasn't been made for over 50 years is going to be real hard...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1550435 06/23/2024 11:00 PM
True. Pretty much the same with about everything on these old trucks.
3100Apache1959 #1550441 06/23/2024 11:52 PM
Another possibility is Chelsea.
They were/are a manufacturer of PTOs.
