Maybe there is some helpful information from this web source ???
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
The PTO is forward facing for a winch. Problem is that the bell housing cross member is in the way. The 30 degree adapter re-positions it so the line line passes underneath. The PTO appears to be a Dana/Spicer(from research). I'm trying to identify the adapter now so I can attempt to locate one. No luck so far.
That PTO closely resembles one I had on a heavy haul wrecker. It powered a 35 ton belly winch, and it had forward and reverse direction capability. I believe the fwd and rev ratios were slightly different due to different tooth count gears inside the PTO. I don't remember a PTO brand name or part number- - - -I managed that wrecker service in the late 1990s.
Another possibility is Chelsea. They were/are a manufacturer of PTOs.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
