4 members (Shaffer's1950, J Lucas, wilbur53, baldeagle), 107 guests, and 3 robots.
Topics128,079
Posts1,056,297
Members48,441
#154922 09/21/2007 2:56 PM
anybody know the year range of the :confused: GMC General ? :confused: i'm looking for a 77'-79' just wondering if they had any earlyer than 77 ? I'm looking the semi tractor anybod know if the general was offered in a 6x6 tractor form ?
and did GMC make a semi tractor in the 60-66 body style as i haven't seen one yet :confused:
1962 GMC K3000, GMC-379 V6.
might want to move this to the big bolts forum...
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
Quote
There were many. Conventionals up to Series 6500 and Series B which all Road Tractors might have been 7500's.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Here is a picture of a '62 Series 5000.
http://www.gmphotostore.com/prodinfo.asp?number=53217511
GMC 9500 Fan
Detroit Diesel Fan
now thats a sweet looking truck. . .
Tell us more about your '62 GMC. It looks like you have a 351 Toro-Flow Diesel in it. Altho isn't it actually a Series 4000 truck?
GMC 9500 Fan
Detroit Diesel Fan
it's basicly a 1 ton with 8-19.5's and four wheel drive. . . . still has the half ton style front fender's but every one keep's saying it's 1-1/4 ton so basicly the same as 90's 3500HD 4x4 with dual rear wheel's. it's a gas engine. it's a
379M-V6 it was a township's truck. . .i was told the 379 only came such thing's as school buses and county/city truck's. . .when i've ordered part i've call it a C-40 so fare every thing matches up . . .
Driveline:
379ci V-6 gas engine, SM-420 4spd tran's,T-case not sure it's gear driven has
4hi 2hi N 4lo 2lo like the old old dodge's, 5.13 gear ratio 8-19.5 tire's. 60" cab to axle 7FT flat bed. . . engine is alittle doggy but sound oil pressure is 63psi@3,000rpm 57psi@750rpm Hot even!. . .
I'm still looking to 19.5 mudder's. . .
Firestone super all traction.
General super all grip.
Goodyear custom xtra grip.
Y es i did buy set of G171 radial's they tiny compared to the bias tire's.
I remember those. They are kind of rare.
Just for a little extra info, if you actually have a 379, it is not the original engine. I believe the 379's were first out in 1974. Your forum name "351DV6" made me think that you had a Toro-Flow.
By the way, I'm also a B-Model Mack fan.
GMC 9500 Fan
Detroit Diesel Fan
Driveline:
I'm sure with my luck is some cobbled together heap. . . But i don't care she run's drive's stop's. . . some times. . . lol !
The old B61T has the 673end triplex 6.38 gear's 11.00-20 tire's it was a $500 bargan turned into a $10,000 nightmare but she running and driving now. . .
Looks like you got a btie off subect, the question: "did GMC make a semi tractor in the 60-66 body style", short awnser, Yes.
the long awnser: they were built in every style of GMC from the 1960s, they were built from the 105" Conventional Trucks that looked like there little brother the pickups. but there is also the 90" B-model , the 72" steel tilt cab , and lets not forget the good old Aluminum "Tilt-Cab Cruiser" commonly called the "Crackerbox" by truck fans , which was the pre runner to the GMC Astro.
sweet now we got that out of the way. . .
on the other part of that question " what is the year range of the GMC General? "
from best i can tell it's 1977-1988. . . .
now the third part was it offered in a 6x6 tractor still up for grab's . . . .
Quote
Just for a little extra info, if you actually have a 379, it is not the original engine. I believe the 379's were first out in 1974. Your forum name "351DV6" made me think that you had a Toro-Flow. I don't really remember why i used "351Dv6" the 379 came out in for the 73 model year all they V-6's got discoed in 74 but i've seen them in truck as new 79 . . . ohwell
#154934 09/22/2007 10:26 AM
I'm going to guess the awnser your looking for about the GMC General will be in the book, "GMC Heavy-Duty Trucks 1927-1987" &/or "GMC: The First 100 Years".
I see 1976-1987 in one book and 1977-1987 in the other.
as for 6x6, well I guess if some one had a need and the money they could have gotten it that way......
#154935 09/22/2007 12:50 PM
I've seen them as 6x6's, just not in tractor form mostly cement truck's and tree puller's. . .
80's would be too new for my taste tho they look the same. . .so i'll look for the 1977-1979 model's. . .thats about the biggest GMC i know of. . .
Jolly,
You must have missed my first 2 replies.
GMC 9500 Fan
Detroit Diesel Fan
Quote
Just wondering if you have ever checked out a GMC 9500 Extended Hood Tractor (Long Nose).
They were first out in 1966 and went into the '70's.
Big, tough and a classic for sure.
GMC 9500 Fan
Detroit Diesel Fan
9500 GMC I can't say as i have seen one. . .
Here is a GMC 9500 Extended Hood. It is a wrecker. I'll try to find a tractor. They are around the net, but a little hard to find.
http://www.hankstruckpictures.com/pix/trucks/macneil/2004/aug/wilkinsons_wrecker_service.jpg
GMC 9500 Fan
Detroit Diesel Fan
Now that's a Truck. . .
