2 members (G508, Hush),
128
Mod | | | Forums66 Topics128,271 Posts1,058,414 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | anybody know the year range of the :confused: GMC General ? :confused: i'm looking for a 77'-79' just wondering if they had any earlyer than 77 ? I'm looking the semi tractor anybod know if the general was offered in a 6x6 tractor form ?
and did GMC make a semi tractor in the 60-66 body style as i haven't seen one yet :confused:
1962 GMC K3000, GMC-379 V6.
| | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | might want to move this to the big bolts forum...
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Apr 2003 Posts: 943 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 943 | Originally posted by 351DV6GMC40:
and did GMC make a semi tractor in the 60-66 body style as i haven't seen one yet :confused: There were many. Conventionals up to Series 6500 and Series B which all Road Tractors might have been 7500's.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | now thats a sweet looking truck. . .
| | | | | Joined: Apr 2003 Posts: 943 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 943 | Tell us more about your '62 GMC. It looks like you have a 351 Toro-Flow Diesel in it. Altho isn't it actually a Series 4000 truck?
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | it's basicly a 1 ton with 8-19.5's and four wheel drive. . . . still has the half ton style front fender's but every one keep's saying it's 1-1/4 ton so basicly the same as 90's 3500HD 4x4 with dual rear wheel's. it's a gas engine. it's a 379M-V6 it was a township's truck. . .i was told the 379 only came such thing's as school buses and county/city truck's. . .when i've ordered part i've call it a C-40 so fare every thing matches up . . .
Driveline:
379ci V-6 gas engine, SM-420 4spd tran's,T-case not sure it's gear driven has 4hi 2hi N 4lo 2lo like the old old dodge's, 5.13 gear ratio 8-19.5 tire's. 60" cab to axle 7FT flat bed. . . engine is alittle doggy but sound oil pressure is 63psi@3,000rpm 57psi@750rpm Hot even!. . .
I'm still looking to 19.5 mudder's. . . Firestone super all traction. General super all grip. Goodyear custom xtra grip. Y es i did buy set of G171 radial's they tiny compared to the bias tire's.
| | | | | Joined: Apr 2003 Posts: 943 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 943 | I remember those. They are kind of rare.
Just for a little extra info, if you actually have a 379, it is not the original engine. I believe the 379's were first out in 1974. Your forum name "351DV6" made me think that you had a Toro-Flow.
By the way, I'm also a B-Model Mack fan.
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | Driveline:
379ci V-6 gas engine, SM-420 4spd tran's,T-case not sure it's gear driven has 4hi 2hi N 4lo 2lo like the old old dodge's, 5.13 gear ratio 8-19.5 tire's. 60" cab to axle 7FT flat bed. . . engine is alittle doggy but sound oil pressure is 63psi@3,000rpm 57psi@750rpm Hot even!. . . I'm sure with my luck is some cobbled together heap. . . But i don't care she run's drive's stop's. . . some times. . . lol !
The old B61T has the 673end triplex 6.38 gear's 11.00-20 tire's it was a $500 bargan turned into a $10,000 nightmare but she running and driving now. . .
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | sweet now we got that out of the way. . . on the other part of that question " what is the year range of the GMC General? " from best i can tell it's 1977-1988. . . .
now the third part was it offered in a 6x6 tractor still up for grab's . . . .
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | Originally posted by C10 - C90 Bill: I remember those. They are kind of rare.
Just for a little extra info, if you actually have a 379, it is not the original engine. I believe the 379's were first out in 1974. Your forum name "351DV6" made me think that you had a Toro-Flow. I don't really remember why i used "351Dv6" the 379 came out in for the 73 model year all they V-6's got discoed in 74 but i've seen them in truck as new 79 . . .
| | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | I'm going to guess the awnser your looking for about the GMC General will be in the book, "GMC Heavy-Duty Trucks 1927-1987" &/or "GMC: The First 100 Years".
I see 1976-1987 in one book and 1977-1987 in the other.
as for 6x6, well I guess if some one had a need and the money they could have gotten it that way...... | | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | I've seen them as 6x6's, just not in tractor form mostly cement truck's and tree puller's. . .
80's would be too new for my taste tho they look the same. . .so i'll look for the 1977-1979 model's. . .thats about the biggest GMC i know of. . .
| | | | | Joined: Apr 2003 Posts: 943 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 943 | Jolly,
You must have missed my first 2 replies.
| | | | | Joined: Apr 2003 Posts: 943 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 943 | Originally posted by 351DV6GMC40: thats about the biggest GMC i know of. . . Just wondering if you have ever checked out a GMC 9500 Extended Hood Tractor (Long Nose). They were first out in 1966 and went into the '70's. Big, tough and a classic for sure.
| | | | | Joined: May 2007 Posts: 292 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 292 | 9500 GMC I can't say as i have seen one. . .
