5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
What year 235 are engine parts ready available. Rebuilding an old 1954 235 has become quite difficult. cry
Thanks Red
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Have you tried RockAuto? There's a discount code available for them HERE.
Looks like they have about everything but valves and crank bearings.
No 54 mains
"Back In Time"
Follow in the DITY
Red,
PM Hotrod Lincoln, he can explain how to modify the block and main caps to enable using 1955 and up mains , which are available. I could try to explain the proceedure but I'd rather you contact Jerry and get it straight from him.......
Ron - - Dusty53
1954 Chevy 3604
There's also a way to modify the block and the crankshaft to use main bearings for a small block 400 V8, but it involves machine work that most shops are unwilling to attempt.
Thank You
Red
"Back In Time"
Follow in the DITY
