4 members (DadsFirstPickup, Maybellene, Cletus1950, tclederman), 143 guests, and 5 robots.
Topics128,108
Posts1,056,231
Members48,436
I have a '63 Chevy C10. Someone has changed the engine to a 70's straight 6. should be a 250CID... The engine block #'s are 370686.....
Any Help would be Great ...
Thanks.
Your engine block casting# doesn't match any of my resource listings. It seems to lack enough digits. Perhaps you can post pictures of the block and head casting numbers plus the stamped serial number from the machined pad next to the distributor??? More info is needed to try and help you ID your engine. wink
~ Dan
1951 Chevy 3 window 3100
Socket Breaker
Socket Breaker
Yes, more details please.
The experts will get you sorted out.
-Woog
on the engine #s here is what I found. Really just looking for a new carb or someone to rebuild this 1 bbl rodchester....
Thanks for all the help...
If you have even fair to middlin' mechanical skills, you can rebuild that carburetor yourself. People here will talk you through it step by step if necessary.
1950 Chevrolet 3100 (Ol' Roy)
A "rebuilt" Rochester is still a Rochester. Don't get your hopes up too high!
Tob, The casting# 366855 decodes as a GM (Chevy/Buick/Olds/Pontiac) 250 I6 used form 1966-84. To further ID your engine, please look for and provide the engine serial# which is stamped into a machined pad surface just to the left of the distributor where it's enters the block. You may need to clean off some paint and road grime to see the info. That can be used to further ID what you have. wink
~ Dan
Dan,
Thank you for the info..
smile
