11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith),
78
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 54 | Hi, I have a mustang II front clip on my GMC COE, i have coilover shocks, but the front is so floaty, I have 600lb springs, but the with weight of the cab, and engine right over the axle, i think i need way stronger springs, i have seen elsewhere someone saying he used 900lb springs anyone here knowledgable on what i should do? many thanks sam | | | | | Joined: Jan 2022 Posts: 2,441 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,441 | Just curious. How much weight is on the front tires? Is a M II designed for that much weight?
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Take a look here: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1527810/re-dialing-in-mustang-ii-ifs.htmlWe helped Craig work through a lot of these issues and the process/equations are there. I would second the question above about how much weight the MII kit you have is rated for. A COE ofter has a lot more weight up front than other types of vehicles. | | | | | Joined: Feb 2004 Posts: 29,759 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,759 | An M-II under a COE sounds like you're sending a boy to do a man's job. Wouldn't it be better to start out with a bolt-in front crossmember, springs, and upper and lower control arms from a mid-1980s C20 or something similar? At least you'll have a suspension system designed for an almost full grown truck- - - -not a subcompact car. The spindles, hubs, and brakes will also be designed for truck use, not for some girly car. Jerry
