6 members (Otto Skorzeny, Gray_Ghost, Jon G, 51sub, Peggy M, BC59), 153 guests, and 8 robots.
Topics128,098
Posts1,056,165
Members48,436
#1548654 06/04/2024 9:54 AM
Hi,
I have a mustang II front clip on my GMC COE, i have coilover shocks, but the front is so floaty, I
have 600lb springs, but the with weight of the cab, and engine right over the axle, i think
i need way stronger springs, i have seen elsewhere someone saying he used 900lb springs
anyone here knowledgable on what i should do?
many thanks
sam
1959 Apache
""Rebuit everything and added a 440 Big Block"
Follow in the DITY
Just curious. How much weight is on the front tires? Is a M II designed for that much weight?
Take a look here: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1527810/re-dialing-in-mustang-ii-ifs.html
We helped Craig work through a lot of these issues and the process/equations are there.
I would second the question above about how much weight the MII kit you have is rated for. A COE ofter has a lot more weight up front than other types of vehicles.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
An M-II under a COE sounds like you're sending a boy to do a man's job. Wouldn't it be better to start out with a bolt-in front crossmember, springs, and upper and lower control arms from a mid-1980s C20 or something similar? At least you'll have a suspension system designed for an almost full grown truck- - - -not a subcompact car. The spindles, hubs, and brakes will also be designed for truck use, not for some girly car.
