6 members (Wheelie, 1955 1 Series, Donf, Woodcmiami, 2 invisible), 100 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#1548099 05/28/2024 2:07 PM
I’m asking for general knowledge. During the Advance Design period, or before or after, did Chevrolet (or GMC) equip big-bolt trucks with Budd wheels? Thanks!
Professional Novice
Frank50 #1548108 05/28/2024 2:57 PM
7
7 Offline
I think starting in 1955 they had Budd as an option, my '57 2 ton has 6 lug Budds.
Frank50 #1548166 05/29/2024 3:03 AM
Chevrolet first started using Budd wheels for the 1956 model year on their 5, 6, 7, 8, 9 & 10000 series trucks.
I don't know when GMC started using them...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Frank50 #1548174 05/29/2024 10:13 AM
7
7 Offline
Thanks Mike.
Frank50 #1548186 05/29/2024 3:03 PM
Thanks for the responses.
If I understand correctly, you must use Budd wheels with Budd hubs, studs and nuts. Right? Thanks.
Professional Novice
Frank50 #1548242 05/30/2024 2:18 AM
I've never tried to put a Motor Wheel on a Budd Wheel hub or vise versa, but yes you need to use the Budd wheels with Budd nuts. The nuts are cone shaped to center the wheel on the hub (stud piloted)...the Budd Wheels lug holes are all conical shaped to accept the cone nuts (inner and outer).
The attached picture shows the 1955 and earlier Motor wheel (hub piloted) and the 1956 and newer Budd wheel (stud piloted).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Frank50 #1548332 05/31/2024 2:05 PM
More "general knowledge" for Frank's request. The two pages below are from the 1939-53 GMC Master Parts Book. Sorry, there isn't a magic decoder ring to go along with the manufacturer's code. K.H. would be Kelsey-Hays. I don't know the others.
Bill Hanlon #1548446 06/02/2024 2:33 AM
My guess is "M" = Motor Wheel Corporation. They made hub piloted rims that used a flanged nut to hold the rim to the hub.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1548611 06/03/2024 9:10 PM
My 59 GM dump truck has the Budd wheels with the huge conical nuts, but one of the front rims is a Motor Wheel Corp rim. It slips over the studs fine, the holes just don't use the taper on the lug nuts to align the rim.
You can probably use them on the inside wheel of a dually as those use regular-sized studs compared to the budds.
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
Frank50 #1548747 06/05/2024 12:05 AM
Budd, and Motor Wheels were available on the 47-54 GMC 400 series and heavier trucks.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Frank50 #1549424 06/12/2024 11:13 PM
Thanks all.
Professional Novice
