8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 36 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 36 | Hey everyone, I hope you all had a great memorial weekend. I am getting ready to try and install the rubber pads onto my brake pedal. Are there any tricks to this? I searched but could not find anything on the topic.
1954 GMC Series 1 102-24 Series 1/2 Ton Long Bed 248 to a Hydramatic
| | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | The only thing I have ever tried is to use a bit of time in the sun to soften and allow the rubber to be more elastic when doing the install. Much less chance that you will tear the pad while pulling it around the metal plate.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2019 Posts: 36 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 36 | Do you think that boiling it would work any better? I am not sure max temp is for the rubber but I would think that it would handle 212 degrees.
| | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | No idea on boiling them as I've never tried using boiling water to soften rubber items. I would think a lower temp might be better just to prevent possible rubber degradation. If you try it, let us know how it works out.
| | | | | Joined: Oct 2021 Posts: 6,818 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,818 | I just start at the top and work my fingers all the way around to make sure the lip of the pad is fully on the back side of the metal pedal. Are you gluing yours as well?
I put mine on without glue and they seem to be staying put just fine.
I didn't heat it or boil it or anything.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2019 Posts: 36 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 36 | Thank you all for the advice. I was not planning on glueing them, but will do if they dont want to stay on. To be honest I have not tried to get them on, but did notice that they are fairly stiff and tough and I thought that they will be a real bear to get on the peddle. So started thinking of a solution to a problem that isnt really there...that is the engineer in me. I will give it a try and see how I go.
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 |
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | How about using the rope-in trick like for windshield installation?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Wrap them in a couple of layers of old socks and tumble them in the clothes dryer for a little while, then use a small amount of brake fluid as a lubricant as you install them. A flat tip screwdriver makes a pretty good installation tool.
| | | | | Joined: Jan 2022 Posts: 2,457 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,457 | The last 2 sets of pedal pads I bought (from Classic Parts??) were slightly too small to fit properly on the metal pedals of my '52 GMC 3/4 ton. They'll go on, but won't lie flat. The back outside edge of the pad sticks up because the metal pedal is too big for the space allowed by the pad.
I'll take a picture and post it in the morning, but right now it is pouring down rain outside and the garage is 100 ft away.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | When I put them on my '47 a few years back, I think I just worked them as Otto suggested.
I need to get some for the '59, but haven't pulled the trigger on it yet. If all I order is the two pads, the shipping charges are as much or more than what the pads cost! | | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | I, like Otto and Rich, just worked it on. Wasn’t that hard.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I have had problems with getting them on easily due to stiffness as well as a problem of them falling of later. Go figure. I leave them in the sun, then use black RTV to keep them on. They aren't made correctly in my opinion.
| | | | | Joined: Oct 2021 Posts: 6,818 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,818 | A lot of different places sell them. I wonder if they're all from the same factory or if different vendors sell different ones? Mine was very pliable and stays in place. Mine came from NPD.
| | | | | Joined: Dec 2020 Posts: 1,964 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,964 | A lot of different places sell them. I wonder if they're all from the same factory or if different vendors sell different ones? Mine was very pliable and stays in place. Mine came from NPD. I think thats exactly the case. Different batches or manufacturers. The last set I got fit perfect. There is a top and bottom.58/59
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
