7 members (klhansen, TooMany2count, 68ironhead, cmayna, 60steve, Wally / Montana, 1 invisible),
83
Mod | | | Forums66 Topics128,197 Posts1,057,261 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 11 Junior Member | | Junior Member Joined: Aug 2007 Posts: 11 | so i am told this form is the place to be. we are restoring a 1926 chev fire truck and am looking for help with finding anthing about the soda ash water tanks that came with them. check out the3 old photo @ http://www.flickr.com/gp/12848345@N07/493526
any and all information would help thanks
firefighting stove bolt style
| | | | | Joined: Aug 2007 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 30 | Here is what is written in one of my books.
"A chemical appliance could be for example, a 60 gallon drum of water that could be used on the spot without the need for a pump. The water was expelled by carbon dioxide gas created by the action of sulphuric acid with a bicarbonate solution. The result was a reasonably powerful jet, which was an effective front line of attack until the heavier jets of the main pumps could be brought to bear on the fire. The downside to these appliances is once they had been turned on, they could not be stoppeduntil they had completelyemptied themselves."
Hope this helps as to there purpose. Where you'd find any to do a restoration is beyond me. Good luck. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | do you have the tanks removed or are you looking for tanks to install on the truck? | | | | | Joined: Aug 2007 Posts: 11 Junior Member | | Junior Member Joined: Aug 2007 Posts: 11 | we don't have the tanks. they went missing sometime in the late 60's. we are looking for any part of the tanks, or any drawings to help us build a set
| | | | | Joined: Aug 2007 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 30 | You can try posting a free add requesting info on the tanks at the following link. Someone may have the info you need. http://www.antiquevehicleads.com/home.html | | | | | Joined: Dec 2006 Posts: 16 New Guy | | New Guy Joined: Dec 2006 Posts: 16 | If you want email me and I can pass along some info, our local Fire protection District has a 26, I'm sure they would be happy to help you out. oldgoaly at "G" mail dot com (darn spammer can get your addy if you don't hide it) Come to think of it Lenzburg has a 26 also. Take care tt | | |
