5 members (Wally / Montana, cmayna, UtahYork, Bill Hanlon, TexasA&M48Truck), 131 guests, and 2 robots.
Topics128,197
Posts1,057,259
Members48,466
Junior Member
Junior Member
so i am told this form is the place to be. we are restoring a 1926 chev fire truck and am looking for help with finding anthing about the soda ash water tanks that came with them. check out the3 old photo @ http://www.flickr.com/gp/12848345@N07/493526
any and all information would help thanks
firefighting stove bolt style
Here is what is written in one of my books.
"A chemical appliance could be for example, a 60 gallon drum of water that could be used on the spot without the need for a pump. The water was expelled by carbon dioxide gas created by the action of sulphuric acid with a bicarbonate solution. The result was a reasonably powerful jet, which was an effective front line of attack until the heavier jets of the main pumps could be brought to bear on the fire. The downside to these appliances is once they had been turned on, they could not be stoppeduntil they had completelyemptied themselves."
Hope this helps as to there purpose. Where you'd find any to do a restoration is beyond me. Good luck.
"If you're not first, you're last". Ricky Bobby
1944 Chevy Firetruck
Halloween Decorations
1966 F**d Firetruck
do you have the tanks removed or are you looking for tanks to install on the truck?
Junior Member
Junior Member
we don't have the tanks. they went missing sometime in the late 60's. we are looking for any part of the tanks, or any drawings to help us build a set
You can try posting a free add requesting info on the tanks at the following link. Someone may have the info you need.
http://www.antiquevehicleads.com/home.html
1966 F**d Firetruck
If you want email me and I can pass along some info, our local Fire protection District has a 26, I'm sure they would be happy to help you out. oldgoaly at "G" mail dot com (darn spammer can get your addy if you don't hide it) Come to think of it Lenzburg has a 26 also. Take care tt
