3 members (Steelonsteel, Woogeroo, klhansen), 154 guests, and 3 robots.
Topics128,186
Posts1,057,317
Members48,469
Page 6 of 7 1 2 3 4 5 6 7
AD Addict & Tinkerer
That color looks great. I glad you finally got your paint sorted out. Wow, that was quite an ordeal you went thru!
Now comes the fun part! Congrats!
Phil
Project Journals
Stovebolt Gallery Forum
RLB Offline
Very nice. 👍
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
After entirely too much time to set a bed on, it is down centered and secured.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
RLB Offline
That’s got to feel good
HiPo
And I was able to make a pile of sawdust getting the boards in place. Now I need to drill 64 holes. Found out I was sent one strip with no holes. Not sure how I am going to solve this one?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I'd have the supplier replace that one strip. Unless you have a drill that will make square holes, it's going to be tough to do those. That hole-less strip looks like it's polished stainless vs non-polished on the rest of them.
But the bolts in the strips should go between the boards, so you shouldn't have to drill those.
The other strips have the protective sticker on them still.
Last edited by Gdads51; 05/21/2024 1:21 PM. Reason: fix quote to display correctly
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Unconventional Thinker
Truck looks great! If that one strip was smack dab in the middle, you could have one oddball that bolted from the bottom, assuming it has all-thread welded to it so you can thread nuts on from underneath.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
Hung the hood today. It's not aligned and I need to put springs on hinges, but doing it with myself and I, I consider it a win with all 4 bolts in.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Mirrors on. Fender supports on. Badging on. Marker lights in. Dome light in Hi low beam switch in. Main Wiring is headed in which is going to be a nightmare. .
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Originally Posted by Ferris Bueller
. . . .Main Wiring is headed in which is going to be a nightmare. .
Tedious, yes. Doesn’t need to be a nightmare. Preparation is important. https://lugnutz65chevystepside.weebly.com/diy-wiring-tips.html
I have fought this all weekend. It starts and charges on its own. Whoo hooooo.
Key switch fire
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Congrats on the progress Ferris! Truck's looking great
1940 1/2-ton
Low skill and low buck build
Follow in the Project Journals
In the dark of night, she's a looker.
Why didn't you paint the fender struts?
1950 Chevrolet 3100 (Ol' Roy)
They will be. Just fitted into place.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Had to do.something this evening while.kids were at a dance.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
What's that logo? Was it on the truck when you got it or something?
Authorized Pest
Authorized Pest
Otto, HERE IS a fun side photo when Ferris first got the truck. Check his FIRST POST when he added phohtos.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Gave up on the wiring for a while. Working on glass.
Dropped the rear window twice. Slid down hit the frame, lift arm and onto the concrete. Tough stuff for sure.
Wing window and window tracks are not fun with new paint.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Rear window for me was the worst! Your truck looks good. Hopefully will get to my door glass and wing windows this month.
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
Your truck looks amazing. Nice job!
Phil
Project Journals
Being unemployed has its advantages.
Little did I know you can't install wing window until you do the rest of the glass. Well that is done now on both sides.
Original glass cleaned up decent. I.may need to.polish it next winter. Moving onto the bed strips now. Have 64.holes to.drill in the cross.beams.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Ran out of time tonight. Only have a few holes left to drill. I changed to standard composite lumber so none of the holes lined up in cross sills. Needs a good cleaning, but I like it vs oem wood.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Is that plastic like Trex?
Otto - Yes. I would suggest solid vs the corrugated stuff.
Last edited by Peggy M; 06/07/2024 2:08 PM. Reason: Remove quote - not necessary ;)
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Somebody got some wiring figured out. Tail lights and markers. Check
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
So these two pics are 2 years 9 months apart. Truck is loaded up to get an exhaust system and a windshield. Could not believe I could get the windshield and install for the same money as buying it from lmc
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Beautiful transformation.
I hope to be doing the glass portion of my project later this year, pending painting and assembly. I had my exhaust done with just the cab on the chassis although the exhaust shop did want the rear bumper and at least a portion of the bed installed to verify clearances.
1949/50 3600 Project
Follow in Project Journals
RLB Offline
Looking good. You’ve done a great job so far!
HiPo
Been busy with family cap, and starting a new job. Have to grab pic of the glass, but the AL trim is worth every penny as is the chrome accent for rear window.
Exhaust is complete. Dumb money, but its all stainless, and my cutouts dump back into the exhaust pipe. I got it as quiet as I could with the mufflers. I hope its not droney when traveling at speed.
Here is both exhaust notes. 383 with and without mufflers, and 283 without mufflers at idle
Exhaust with electric cutouts
Original 283 wide open exhaust.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
A big thanks to Hambone for gifting me a headlight switch two years ago. After a bad light bad ground and a bad switch I have headlights again. I made markers run with headlights too because I just like it that way. Got pics of the windshield and rear window trim. I like the bling on these trucks because there was not much available.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Must be getting real close now. Enjoy that first drive to be transfer station.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone, i have so much wiring to do.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Trim looks really nice.
Got most of the gauges wired in. Very nice actually knowing I have oil psi.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Your efforts are paying off, your truck looks great! Nice job!
Phil
Project Journals
Little stuff this weekend. All gauges functioning. Other side of bed boards complete. Sill plates in. Seat back in from.wiring. License plate bracket installed. Hambone's gift of a.stovebolt plate installed. Wheels polished.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I like.
Authorized Pest
Authorized Pest
Ferris, the truck does look incredible. thumbs_up I see you've got the Stovebolt License Plate. Yaa-hoo. We have a fellow Bolter going to make up a bunch for us. We had to send him our last one so he could see what kind of material it's made out of. We think it's pretty sturdy and a good color. smile
~ Peggy M
1949 Chevrolet 3804
I snuck across town into Laconia for a cruise night. No plate on truck yet but I wanted to show off a little. Tape still on it, wiring looking terrible, etc.
While I was out looking at other rides the sponsor had his waitresses pose next to my truck.
Pic was sent to me.later.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Moderated by  Phak1
