3 members (Otto Skorzeny, Rusty Heaps, Steelonsteel), 108 guests, and 2 robots.
Topics128,034
Posts1,055,536
Members48,425
#1547252 05/17/2024 1:18 AM
Thought i had seen a hood safety pin, one to keep the hood from coming up while going down the road. After experiencing this a couple times in the past, fortunately at low speeds and knowing how scarce parts are getting, i get nervous when i meet a big truck. Anybody got any ideas, lowbuck if possible.
blu1964 #1547270 05/17/2024 3:19 AM
These look like they won't break the bank.
You truck should have a safety hook, but these are more secure, although harder to mess with.
blu1964 #1548480 06/02/2024 6:38 PM
I took one of the bolts out of the cover between the radiator support and the grille support, that holds the triangle shaped shield in (not sure what its called. Run a 6in. stove bolt up, drilled a hole in bottom lip of hood, drilled a hole in the bolt and put a 3/16in lynch pin with a fender washer below it. Once painted black it will "disappear". Total cost about 3 bucks, not show quality, but not hideous.
