7 members (MickeyP, RoadsScholar, fonz8261, 37 GC, Otto Skorzeny, Biermann, Hugh63c10),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | The rear half of the driveshaft in my 55 GMC 630 was removed when I acquired it, but came with it. I'm cleaning up and repacking the disassembled u-joint. The locking tab plates are marked "USE OIL". I'm accustomed to greasing u-joints, not oiling them. What am I missing?
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | Does the cross have a zerk? I would use high temp smooth grease regardless.
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Yes, it has a zerk. I plan to use good grease....I was really scratching my head about the oil notation.
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | FYI for anyone curious: I found in a vintage GMC maintenance manual that the "oil" which is specified is SAE 50. If I had to guess, I would say that, except for when it came from the factory, it has had grease pumped into the joints for every maintenance thereafter.
