10 members (Gray_Ghost, Nick in Manitou, Gdads51, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, LAROKE, 2 invisible), 107 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
#1544740 04/22/2024 5:08 PM
Crusty Old Sarge
Crusty Old Sarge
I am not sure if this has been shared here before, but as I have been researching wheel bearings for some time it's worth sharing again. I was having problems trying to locate tapered roller bearings for the front of my "58 4400 "Thor". I had worn out my welcome at all the FLAPS in town, NAPA was trying hard but just couldn't find a match. Taking the measurements from the actual cones and races I buried myself in the internet, everything just brings another rabbit hole.
I did finally come across a site that allows you to enter bearing measurements and search in that forum. This site gives you options for bearing type as well as dimensions. The end is a real Part Number that crosses to a Timken, National or SKF number. Using this I was able to locate bearings and get them ordered through Amazon at a greatly reduced price.
Please take a moment and check out this link. https://bearingfinder.ntnamericas.com/
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Cool!
BC
1960 C60 pasture art
I will use this. Nice work and thank you for thinking of the rest of us!!
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
Thank You TUTS 59!
-David
1953 2-Ton GMC
V
VEW Offline
V Offline
Good source. Maybe the administration (Peg) can make it a sticky one n the appropriate forum
~ Victor
1957 3100 - moved on
24601
Peggy isn't the *only* one around here, you know ...
Seems to be a site applicable to all of Stoveboltdom, ja? Let's move it to Driveline if only wheel bearings. We could move it to General Truck if all types of bearings (wheel, tranny, engine, etc, etc., etc...). If we get enough positive feedback, we could consider possible follow-on options. Like making it a sticky ... making it a Tech Tip of sorts ... or something else. I *do* have an open mind about these sorts of things, you know ... wink
So ... where to move it??
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Crusty Old Sarge
Crusty Old Sarge
The site is for all types of bearings. Automotive and industrial would the most used by Bolters.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
