| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The cab seems to be shrinking and I am not as agile as years ago and thinking about adding power steering so I can go with a smaller steering wheel,other then a M II front suspension with a power rack are there any other options and is there anyone making power steering pump brackets and crank pulleys for a 235 | | | | | Joined: Sep 2010 Posts: 1,706 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,706 | I've thought about electric power steering for my '38. I believe there is room under the dash. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm running Mll on my 37 but i used a buick column with tilt and used a smaller Grant steering wheel. Sad part i put on a few lbs or the steering wheel got bigger.
....never bad a problem with my front end. I do wish I'd hsve used the bigger GM rotors for more stopping power. I have a tendency to go fast at times! | | |
