4 members (50Chevy3100, Nick in Manitou, Phak1, 1 invisible), 85 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
Is there any quality difference between Counterpart and Dynacorn. I am looking to purchase quality parts. Also looking for advice on squaring and bracing the cab before I start cutting out the old parts. See attached.
Red
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Dynacorn is supposed to be the highest quality, but I have used other parts in my restoration with decent results. There are some differences in the fit of the inner cowl panels, which it looks like you'll need to replace. I had similar damage to my cab. Definitely brace the door opening after verifying the door fit. You can remove the doors after taking measurements, or the safest thing is to have the doors in alignment and brace across the interior of the door openings before removing them. I also braced between the lower door hinges across the cab using dimensions from the Factory Assembly Manual.
You can browse thru my photos (link in my signature) for some ideas. I'm sure others will chime in as well.
