1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,902 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,902 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2024 Posts: 61 'Bolter | | 'Bolter Joined: May 2024 Posts: 61 | Otto Appling is about 25 miles from The Augusta National golf course . MASTERS West of Augusta up i20 going toward Atlanta. Appling is about 5 miles off of I 20 Ol’’Roy is a Tough Beast to deal The Atl Traffic | | | | | Joined: Dec 2019 Posts: 441 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 441 | The ‘37-39 all use the same gauges, then changed to rectangle like the car in ‘40. ‘38 moved the tank filler outside but kept the split seat.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you ever go 12 volt the chrome trim ring will fit over rim of 260Z and maybe 280Z......they same for few years just have different color scheme......just so you know, just in case! | | |
