Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#154605 08/31/2007 5:55 PM
Has anyone removed the yolk to get at the seal on a Chelsea PTO? I have been trying to get mine off without luck. I had to remove the set screw with an endmill but I cannot drive it off. Heat is my next option unless someone has some enlightening news. Thanks all!
240,000 worker bees!
1960 Two ton Chevy
#154606 08/31/2007 6:24 PM
Beewrangler,
Would a 2 jaw gear puller work? I thought the yokes had two setscrews 90&deg apart.
Stuart
#154607 09/01/2007 5:00 AM
if the seal is shot, i would take the blue wrench to it. use a puller while it's still hot.
#154608 09/01/2007 6:07 PM
Little heat, little pull, lotta brew! Came off like a charm! Thanks men.
1960 Two ton Chevy
