1 members (Ponchogl),
108
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Has anyone removed the yolk to get at the seal on a Chelsea PTO? I have been trying to get mine off without luck. I had to remove the set screw with an endmill but I cannot drive it off. Heat is my next option unless someone has some enlightening news. Thanks all!
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Beewrangler,
Would a 2 jaw gear puller work? I thought the yokes had two setscrews 90° apart.
Stuart | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | if the seal is shot, i would take the blue wrench to it. use a puller while it's still hot. | | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Little heat, little pull, lotta brew! Came off like a charm! Thanks men.
